any tricks to installing a brake booster?
Old Jun 9, 2003 | 04:38 PM
spencedogg's Avatar
Default any tricks to installing a brake booster?
Hey guys are there any tricks to installing a brake booster like maybe removing the dash or something? Let me know
thanks
Old Jun 9, 2003 | 04:41 PM
tonyxcom's Avatar
Default Re: any tricks to installing a brake booster? (spencedogg)
nope, just make sure you know what you are doing.
Bleed your brakes very thoroughly and check your fittings for leaks, they typically need to be pretty ******* tight.
Old Jun 9, 2003 | 04:46 PM
EKRacer's Avatar
Not really...the hardest part might be wiggling it in there depending on the motor/car. Just lay the seat back(or take it out), lay up under there and bolt it in.
The Haynes manual has some kind of procedure about measuring this and that and adjusting, but I didn't do any of that. Just don't twist your little bracket that attaches to the pedal before you put it in and you'll be alright. Trust me, getting it adjusted right again is a bitch.
Old Jun 9, 2003 | 04:55 PM
spencedogg's Avatar
thanks guys any other help would be nice guys
Old Jun 9, 2003 | 06:59 PM
spencedogg's Avatar
up
EKwreckRLS
Suspension & Brakes
Aug 3, 2012 02:23 PM
peanut butter
Aug 15, 2007 05:57 AM
justforkicks
Sep 16, 2006 06:18 AM
B18C Turbo
Aug 30, 2006 12:46 PM
special_edition
Mar 29, 2004 08:07 PM
