KYB AGX's blow?
Old Jun 9, 2003 | 03:34 PM
Jdm93civic's Avatar
Default KYB AGX's blow?
I have searched this topic and it looks like people are saying that kyb agxs are prone to blowing if your car is droped 2 inches....has anyone had this problem......i was going to get AGx's now i might get tokico instead...any one got a problem with AGXs on a 93 civic coupe....
Old Jun 9, 2003 | 03:37 PM
B_CRUZ!'s Avatar
Default Re: KYB AGX's blow? (Jdm93civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdm93civic &raquo;</TD></TR><TR><TD CLASS="quote">I have searched this topic and it looks like people are saying that kyb agxs are prone to blowing if your car is droped 2 inches....has anyone had this problem......i was going to get AGx's now i might get tokico instead...any one got a problem with AGXs on a 93 civic coupe....</TD></TR></TABLE>
yeah because these shocks were actually built for performance, not a stunna stance.
Old Jun 9, 2003 | 03:45 PM
soslow93's Avatar
i have these paired with nuespeed race springs and there grrrreeeaaattt. no problems yet.
Old Jun 9, 2003 | 03:46 PM
JaeOne3345's Avatar
i personally run nuespeed race springs with rates of 435lbs. F and 330lbs R on my 93 civic coupe. i also have the kyg agx 4 way adjustables and ST front and rear sways. i been on them about a year. they have held just fine. the springs are supposedly a 2.25 drop in the front and 2 inches in the rear, but its nothing close to a stunna stance.
kyb has to have some limit and cut off point to advertised recommended lowering. ive heard of this "no more then 2 inches lowered" for a warranty to work, but my car has done fine. and they can tell if the car was lowered more then 2 inches by taking the shock apart and looking at wear marks/patterns.
my advice to you is match your springs accordingly, so one or the other is not doing too much work, thereby decreasing its capability to do its job. suspension work is a system. plan accordingly. you'll blow anything if its not matched properly.
this is a pic of my car for reference:
Old Jun 9, 2003 | 04:54 PM
EKRacer's Avatar
JaeOne3345 is right. There is a statement on the warrenty card saying that they're not covered for anything below 2".
I only used the eibach pro-kit, so I don't know about them blowing.
Old Jun 9, 2003 | 05:26 PM
civictypenos's Avatar
my coupe is dropped at leat 2 inches and no problems for 2 years now
Old Jun 9, 2003 | 06:17 PM
skamal's Avatar
Default Re: KYB AGX's blow? (civictypenos)
I run mine with sportlines, they've been great for me so far.
Old Jun 9, 2003 | 06:20 PM
Jet Phi's Avatar
Default Re: KYB AGX's blow? (skamal)
i got skunk2 race springs on kyb agx's for about 8 months now . . .
about . . . 2 1/2 drop all around
still running strong
Old Jun 9, 2003 | 06:31 PM
kefka's Avatar
Default Re: KYB AGX's blow? (O dohc O vtec O)
uh-oh, how many inches do you think this is? whatever the result is mine arent blown yet...
Old Jun 9, 2003 | 06:41 PM
civickidd99's Avatar
Default Re: KYB AGX's blow? (eh neo)
whatever your drop is camber correction is your friend!
Old Jun 9, 2003 | 06:43 PM
kefka's Avatar
Default Re: KYB AGX's blow? (civickidd99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickidd99 &raquo;</TD></TR><TR><TD CLASS="quote">whatever your drop is camber correction is your friend!</TD></TR></TABLE> these pics are old, camber has been corrected since them..
Old Jun 9, 2003 | 06:49 PM
Hatch_00's Avatar
I have Ground Control with KYB AGX adj. and my car is slammed i bought them from a friend...He had them on his Si and his car was slammed this was about a year ago and they are still a comfortable ride or should i say they havent blown...
Old Jun 9, 2003 | 06:50 PM
Jdm93civic's Avatar
Thanks for the info guys my car is not that low i am riding on GS rims and GC the body is right over the tire so i think i should have no prob....thanks........
Old Jun 9, 2003 | 06:51 PM
JaeOne3345's Avatar
for? saving your tires? if so, an alignment setting toe to factory specs or even zero all the way around will do more to save tires then a camber kit will.
Old Jun 9, 2003 | 08:56 PM
80884's Avatar
Default Re: KYB AGX's blow? (JaeOne3345)
2000 civic KYB AGX, eibach pro-kit, no problems. And yes camber is your friend. camber, caster, toe, aren't these all done with an alignment....
Old Jun 9, 2003 | 09:07 PM
kefka's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">
for? saving your tires? if so, an alignment setting toe to factory specs or even zero all the way around will do more to save tires then a camber kit will.</TD></TR></TABLE> nice
Philip
Oct 21, 2005 08:59 PM
mushu315
Apr 26, 2004 10:36 AM
Jdm93civic
Oct 13, 2003 05:32 PM
weakGOODJunKieS.com
May 7, 2003 05:30 PM
