sunroof leaking HELP!!!
My car has been sitting awaiting major body work and we have been getting trmendous amounts of rain lately....I went to go into my car to start her up and there was like an inch of water behind the seats on the floor........I am almost positive it is the sunroof it could be nothing else how do i fix this problem is there somewhere I can but new weatherstripping or something for my crx all the way around?
there are four drain holes on the car. 2 in the frt corners and 2 in the rear. if you open the sunroof you can see the 2 in front but the 2 in the rear are the ones that sometimes get clogged up with dirt. the drains have tubes attached to them and they run all the way to the rear to drain out. if you can take a air blower with a wand attachment and stick it in each drain and try to blow them out
Guest
Posts: n/a
same thing happened to me on prom night! haha but anyway man its the drain holes the two in the front are easily accessible open the sun roof and you will see them in the front part blow it out with an air compressor...the 2 in the back are hard to get to you have to get inside your car and pull the roof **** back to get to them honda will do it for 65 bucks but you can just do it yourself.......also check your lineing
The rear drain lines usually plug at the back of the car where they exit out behind the rear wheels. You can get to them via the access panels inside the hatch that cover the rear brake light bulbs. There is a 3/4 inch diameter tube that you will see all the way against the side( they come down both C-Pillars). Just pull it out from the bottom and have a cup ready. It usually plugs at this point.
GroundZer0 336
Mar 15, 2003 05:29 AM
