adjusting koni perches w/out removing spring/shock?
Old Jun 9, 2003 | 01:05 PM
sjteg's Avatar
Default adjusting koni perches w/out removing spring/shock?
I was wondering if i can raise my koni perch without removing the spring/shock assembly? if possible, how would i go about doing this? My car is too low right now and i'd like to raise it back up a little. Thanks
Old Jun 9, 2003 | 01:20 PM
sjteg's Avatar
Default Re: adjusting koni perches w/out removing spring/shock? (sjteg)
bump..
Old Jun 9, 2003 | 01:57 PM
Tweakmeister's Avatar
i imagine you could just fit some spring compressors on there and slide the clip down.
Old Jun 9, 2003 | 02:36 PM
sjteg's Avatar
Default Re: adjusting koni perches w/out removing spring/shock? (Tweakmeister)
yeah thats what i was thinking... i need to raise it though.
Old Jun 9, 2003 | 03:40 PM
JCushing's Avatar
i can do it with my ground controls cause when the car is jacked up i can just lift up the spring and move the clip. if you have long springs you might need to compress them.
Old Jun 9, 2003 | 04:46 PM
sjteg's Avatar
Default Re: adjusting koni perches w/out removing spring/shock? (JCushing)
alright i guess i'll try it out. I have neuspeed races. Thanks alot
Ef4doorwagon
Dec 16, 2015 12:54 PM
mikzsan
Suspension & Brakes
15
May 8, 2012 02:44 PM
DcLs
Sep 22, 2008 10:12 PM
KOREAN
Suspension & Brakes
Dec 5, 2006 01:14 PM
GSR2NR
Apr 25, 2002 12:54 PM
