itr valve springs with ctr cam in a gsr.....
VAFC and/or rechipped ECU to move the VTEC x-over and increase the rev limit (rechipped ECU).
Hondata or any other form of standalone is the other option depending on current and future needs.
im going to be using stock itr valve springs.... is there anything else that is needed? i was told ITR retainers/LMA's... but dunno if that is neccessary...
Retainers are universal B-series units....P30's or PR3's.
LMA's aren't necessary with ITR cams; optional.
thanks.... just for safe measures... if you were to use ctr cams in your gsr.... what are the typical upgrades that are needed to allow these cams to run safely? ppl were mentioning valve float might occur.. while others say it wont, so basically im stumped on this on.. i know its a simple question.. but i just need a little help to get me going...
I am using CTR cams right now in a B18C1 engine.
All you need are the valvesprings. Everything else is just to tweak it.
Ryan C
11
Nov 25, 2003 06:35 PM
Dammit_Dan_954
Nov 22, 2003 12:27 PM
97itr86
Oct 3, 2003 12:02 PM
