Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Dual Master Cylinder Sizes?
Old Jun 9, 2003 | 11:43 AM
autorex's Avatar
Default Dual Master Cylinder Sizes?
Anybody out there convert their car to a dual master cylinder setup? I'm in process of doing this to my CRX and I'm not sure what size cylinders to use. I figure 3/4" for the rear and 7/10" for the fronts, but I'm not sure.
Old Jun 9, 2003 | 02:40 PM
IP2GSR's Avatar
Default Re: Dual Master Cylinder Sizes? (autorex)
I think the answer here is that it depends..... The relative size of the master to the caliper will determine the amount of force exerted on the rotor. You will want to maintain the ratio front to rear to not upset the balance too far. The volume of the master to the volume of the caliper and the motion ratio on the brake pedal will determine the stroke of the pedal. You don't want too much or too little stroke.
While I can't be much more help than that, you may want to look at:
http://www.mitchellsoftware.com/prod05.htm
Hope that helps
Dave
#72 IP2 GSR
Old Jun 9, 2003 | 06:44 PM
markw's Avatar
Why? Throw a 90-91 EX MC on it. I'm running teg calipers with 11" VW rotors (Fasbrakes kit) and teg rear disks on my 90 DX Hybrid, and that thing will put your eyeballs through the windshield. 80 miles at Holtville 2 weeks ago and NO fade. Stock used to be gone in 2-3 laps. The cars only weigh 2000+/-100 lbs stock.
Old Jun 9, 2003 | 08:14 PM
autorex's Avatar
Default Re: Dual Master Cylinder Sizes? (markw)
Because I'm building a Production car and SCCA requires that I put in a dual master cylinder setup.
ZCHondaCRX91
Suspension & Brakes
Apr 7, 2011 03:07 PM
ef8mugen
May 20, 2009 08:22 AM
skaterdx
Jan 9, 2005 10:40 PM
Un0Turb0-WP
Oct 18, 2004 02:14 PM
silverkorn
24
Jul 31, 2003 09:02 AM
