IACV..Which ones fit?
Old Jun 9, 2003 | 08:24 AM
Vinceg99's Avatar
Default IACV..Which ones fit?
OK did a search and also posted in the EG forum and it didnt seem like any of them knew anything???
OK I was wondering if there were other IACV's that bolt onto the Z6 IM besides the Z6 one? I tried the A6 one but the bolt holes dont line up. Anyone know if other ones fit besides the original?
TIA!!
Old Jun 9, 2003 | 08:28 AM
SIRX's Avatar
Default Re: IACV..Which ones fit? (Vinceg99)
what an odd time for you to be on-line. I had to check the clock and make sure it said am and not pm . Anyway the zc is the same as the a6 so that checks that box for you. sorry I couldn't be of more help
Old Jun 9, 2003 | 11:14 AM
Redline130's Avatar
A B16A or B18B one will fit.
Old Jun 9, 2003 | 11:50 AM
raene's Avatar
Default Re: IACV..Which ones fit? (Redline130)
Are you sure about the B16A one? Are you referring to the JDM 1st gen? Because I know the A6 one will fit a B16A - meaning it would probably not fit his Z6. How do I know this? I'm using an A6 IACV right now.
Old Jun 9, 2003 | 11:17 PM
Vinceg99's Avatar
Default Re: IACV..Which ones fit? (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">what an odd time for you to be on-line. I had to check the clock and make sure it said am and not pm . Anyway the zc is the same as the a6 so that checks that box for you. sorry I couldn't be of more help</TD></TR></TABLE>
So here is this a better time??
OK so the ZC one is the same as the A6 and also when I did a search people had said that the A6 fits on the B16a Which was already stated so another one that doesnt work. I guess if I can get enough that dont work I might be able to actually figure out which ones do fit!!!
Old Jun 9, 2003 | 11:56 PM
AbaZ's Avatar
It's simple, any OBD1 + Idle air control valve will fit.. (swapable with the z6) So, GSR, B18b etc etc..
ZC/B16a 1g/A6 etc.. all have a wider bolt pattern (all obd0)
Jeff
Old Jun 10, 2003 | 12:01 AM
Redline130's Avatar
Default Re: IACV..Which ones fit? (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure about the B16A one? Are you referring to the JDM 1st gen? Because I know the A6 one will fit a B16A - meaning it would probably not fit his Z6. How do I know this? I'm using an A6 IACV right now. </TD></TR></TABLE>
Sorry about that, Raene is correct. I thought I used a Z6 one on my B16, but I forgot that I have an ITR manifold as well. The stock 1st gen B16 uses the IACV with the wider bolt pattern.
Old Jun 10, 2003 | 12:30 AM
Vinceg99's Avatar
Default Re: IACV..Which ones fit? (AbaZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbaZ &raquo;</TD></TR><TR><TD CLASS="quote">It's simple, any OBD1 + Idle air control valve will fit.. (swapable with the z6) So, GSR, B18b etc etc..
Jeff
Thanks!!
civic_d16y7
Jul 7, 2006 10:11 AM
WH0R3nEF9
Sep 13, 2005 07:21 PM
jobe_149
Jan 27, 2005 05:19 PM
rough_draft
May 12, 2004 07:45 AM
Vinceg99
Jun 8, 2003 01:04 PM
