question skunk 2 cams
Old Jun 9, 2003 | 05:49 AM
sshaikh01's Avatar
Default question skunk 2 cams
What is the difference between skunk 2 stage 1 cams.
and the skunk 2 stage 2 cams.
Old Jun 9, 2003 | 06:40 AM
JD_B18CDX's Avatar
Default Re: question skunk 2 cams (sshaikh01)
Stage 2 cams are more aggressive.
Stick with stage one cams is you have boltsons.
Stage 2 cams will require higher comp ratio, check for valve to piston clearance, porting....etc.
