What PSI should i use on my tires?
Old Jun 8, 2003 | 10:53 PM
Dels98R's Avatar
Default What PSI should i use on my tires?
hi i got toyo proxies for my itr i was wondering what psi should deflate them too, street and drag strip?
Old Jun 9, 2003 | 03:51 AM
Back in Black's Avatar
Rather OG
Default Re: What PSI should i use on my tires? (Dels98R)
Which tire? You're not running the RA-1 on the street, are you?
Old Jun 9, 2003 | 08:24 AM
Big Phat R's Avatar
Which proxes? T1-S or RA-1? Big difference.
Old Jun 10, 2003 | 07:34 AM
Dels98R's Avatar
Default Re: What PSI should i use on my tires? (Big Phat R)
i believe its the RA-1
Old Jun 10, 2003 | 08:48 AM
Big Phat R's Avatar
Don't use the RA-1 for drag racing - the sidewall is much too stiff.
If you must - try low pressures like 22-24 psi at the strip.
I wouldn't use them on the street - that's a waste - the compound is too soft (excessive wear) and you never get them up to temperature enough for them to achieve maximum grip.
At the track it usually takes 5 minutes of VERY HARD driving to get any heat into them. Once the tires are hot - they stick like glue.
I would try a drag radial if you're into going to the strip - otherwise try tires with softer sidewalls - not R compounds.
boostB4beauty
Jul 9, 2009 08:25 PM
JaYy-DeE-EeM
Mar 4, 2009 10:33 AM
obd1_crx
May 31, 2007 10:59 AM
2point2
May 28, 2004 08:05 AM
ildknyli
Apr 10, 2004 10:32 PM
