spark Plug index washers..... DO they work???
Old Jul 18, 2001 | 04:13 PM
GQ 05YellowEVO8's Avatar
Default spark Plug index washers..... DO they work???
I have a set of spark plug index washers and was wondering if they do make HP on B18C1 Motors.
Old Jul 18, 2001 | 10:04 PM
ITR1227's Avatar
Default Re: spark Plug index washers..... DO they work??? (VTEC-MAN95GSR)
I saw one of those "Horsepower" TV shows where they talked about indexing the spark plugs. I am also interested if this a tried and true method of making a small power increase. I guess the main reason is to get the most efficient burn. I can understand how having them all indexed to the same position would also help ensure each cylinder is firing evenly(making same power). Any real experts out there on this subject?
Jeremy
Old Jul 19, 2001 | 04:41 AM
Mike K's Avatar
Default Re: spark Plug index washers..... DO they work??? (ITR1227)
I always index my plugs. Tip of the electrode facing the exhaust side of the combustion chamber.
I've had good luck with Honda/NGK BKR7E-N-11(Honda p/n 98079-5714J)
-Mike K
Old Jul 19, 2001 | 05:49 AM
sgT's Avatar
sgT
Default Re: spark Plug index washers..... DO they work??? (Mike K)
I wouldnt worry about it too much on b-series motors. Since the plugs
sit in the top of the chamber they arent too shrouded by anything.
These arent those V8s you see on those tv shows
Old Jul 19, 2001 | 06:57 AM
FBP_1171's Avatar
Default Re: spark Plug index washers..... DO they work??? (sgT)
This is a fine tuning detail that will not make noticable gains, but it definitely isn't going to hurt anything. If your car is FI, then I would say it was worth it.
Old Jul 19, 2001 | 09:26 AM
Default Re: spark Plug index washers..... DO they work??? (FBP_1171)
Yeah, from now on I'll just forget about using them plugs. Tanks for the input Steve......indexing those plugs are pretty time consuming.
GSE980
May 13, 2009 11:24 AM
ErikV
Apr 10, 2006 04:39 PM
ReV LiMiT
Jul 8, 2004 03:39 PM
RTW DC2R
Apr 10, 2004 05:23 PM
