HELP!! with harness for a/c
I have a D16y8 in my 91 DX hatch. I'm tyring to hook the a/c up. All the mechanical parts are in working condition (eg. compressor works fine, blower is strong) but my electrical is giving me problems. I have a p28 ECU with a wiring harness for the 91 DX pm5 ecu (coverted from the pm5 ecu to the p28). Does anyone know how the wires should be connected w/ regard to the a/c???? I ALREADY TOOK A LOOK AT THE POST WITH ALL THE ECU'S AND WIRING GUIDES. Everything seems to be in the right place in the harnesses, except the colors of the wires.
HELP!!!! Do i need to simply connect the respective wires (eg. a/c compressor clutch relay to a/c compressor clutch relay???) or is there something in the ECU that isn't working? I've checked the main YELLOW wire to the A/C Compressor clutch relay from the DX side harness and it conducts current just fine. But there isn't current coming from the ECU wen I turn the A/C switch on my dash on and off.
Al_9000
19
Jun 1, 2005 08:49 AM
