215/45/16 Tires
Old Jul 18, 2001 | 03:25 PM
fso_BamBam's Avatar
New User
Default 215/45/16 Tires
Is that what the JMD Type-R has? If so, would this size rub if I got it for my car? My order for S03s is still waiting at the tirerack, so I could change it before it ships. I am currenly getting the 205/45/16s.
Old Jul 18, 2001 | 03:26 PM
Hybrid ctr's Avatar
Default Re: 215/45/16 Tires (fso_BamBam)
no rubbing with stock height
Old Jul 18, 2001 | 03:30 PM
fso_BamBam's Avatar
New User
Default Re: 215/45/16 Tires (Hybrid ctr)
OK, so if I got the Mugen Lowdown suspension, which I will pretty soon, then I am screwed (it lowers the car 3/4 inch, I believe).
Old Jul 18, 2001 | 03:32 PM
N1Spec's Avatar
New User
ive got 215/45/16 lowered about 1 and 3/4 inch, no rub
Old Jul 18, 2001 | 03:33 PM
Big Phat R's Avatar
Not if you have 50mm (stock) offset rims. Even +43 should be ok.
I have 225/40-16s (Pirellis) on my R that is dropped 2" and don't rub. I will probably be able to get a 225/45 under there even
i 4's Avatar
i 4
i think you would be ok actually....but you might have to shave the inside of your fenders.
Old Jul 18, 2001 | 05:16 PM
Jason's Avatar
I just got a set of 215-45-16's and I have it lowered about an inch...no rub, but I had my fenders (rear) shaved a bit...enough clearance for me...I am using +45 offset Spoon wheels too...hope this helps
Old Jul 18, 2001 | 05:55 PM
Dipshit Dan's Avatar
Default Re: 215/45/16 Tires (typer98)
You'll be fine. I highly recommend that size. Falken Azenis tires are now available in that size I believe.
Old Jul 18, 2001 | 06:10 PM
N1Spec's Avatar
New User
Default Re: 215/45/16 Tires (God)
i notice u lose abit of acceleration with the larger diameter, but the extra grip more than makes up for it.
calde-da9
Sep 6, 2007 09:26 PM
PA Geesir
May 3, 2004 04:58 PM
JunIntegra
Jan 24, 2004 11:20 AM
-Gambit-
Nov 9, 2002 03:41 PM
vtecdc2
Sep 22, 2002 08:15 AM
