Brake Lights Stay on???? Help!
Old Jun 8, 2003 | 03:34 PM
HatchBeezy's Avatar
Default Brake Lights Stay on???? Help!
Ok, I think I posted something bout parking lights, but now that I check them....all brake lights on my '93hatch stay on? It drained my battery and it sucks! Is there a lever that goes out behind the brake pedal? Need some helpful info. Thanks in advance! Peace
Old Jun 8, 2003 | 03:53 PM
b18cef's Avatar
Default Re: Brake Lights Stay on???? Help! (HatchBeezy)
I had a similar situation happen to me.
When I would turn my parking lights on, my brake lights would light up and stay on. And if my lights were off and I put my brakes on, it would light up my parking lights while I was applying my brakes.
Come to find out after looking at everything, I had noticed that the filament (sp?) for the brake light had burned up and the end that came loose was touching the filament for the driving/parking lights causing a short.
So you might want to check the rear bulbs for any loose filament that is causing a short....
Only thing that I can think of and share from my experience.
_Brandon
Old Jun 8, 2003 | 07:53 PM
HatchBeezy's Avatar
Cool....I'll check that...anymore suggestions????
Old Jun 11, 2003 | 09:08 PM
Frozen E's Avatar
H-T White Ops
There's a switch on your brake pedal's backside that closes when the pedal is pushed down. If that switch moved in any way and isn't making contact with the actual brake pedal arm anymore, your lights will stay on.
Hope that helped out.
Old Jun 11, 2003 | 09:41 PM
gregcivic92lx's Avatar
New User
Default Re: Brake Lights Stay on???? Help! (Frozen Si)
check the brake light switch ,my guess is it will need to be replaced ,i had that happen on my old gran prix ,hope this info helps u out
Old Jun 11, 2003 | 10:26 PM
TypeRaven's Avatar
Default Re: Brake Lights Stay on???? Help! (gregcivic89dx)
dude just top off your brake fluid resivoir. Most likely that's your problem. It worked for me.
Keston
acura_crx_x71
Sep 1, 2009 05:30 PM
toolbox21
Mar 17, 2009 08:31 PM
Adam.C
Mar 22, 2004 07:35 AM
crexer
19
Jul 18, 2003 02:51 PM
