clutch engagment problems
Old Jun 8, 2003 | 02:05 PM
typeee's Avatar
Default clutch engagment problems
the clutch engagment point seems to be changing. normally the clutch engages about 1 inch from the ground. but yesterday while i was driving, it started engaging right at the end of the stroke (4 inches higher). the pedal also feels a lot harder when pressing it. by the time i got home, it started engaging 1/2 inch from the bottom (now way too low). this morning it's back to engaging at the end of the stroke (4 inches higher), way too high to drive properley.
checked all the fluids and they're all fine. checked all the clutch engagement screws, they're all perfectly fine, not lose or anything.
the car is a totatly stock 2000 itr. 36k miles (58,000 KM)
any idea what's going on here? clutch gone?
thanks,
itr707
Old Jun 8, 2003 | 06:23 PM
b19coupe's Avatar
Default Re: clutch engagment problems (itr707)
You may have had a spring break out from the clutch disc. Sometimes it will get stuck and cause problems, other times it will be out of the way and the clutch will operate normally. That is one likely possibility.
Old Jun 9, 2003 | 05:30 AM
Dr Pooface's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr707 &raquo;</TD></TR><TR><TD CLASS="quote">the clutch engagment point seems to be changing. normally the clutch engages about 1 inch from the ground.</TD></TR></TABLE>
The engagement point for my stock clutch was way near the top, not one inch from the bottom. Weird.
Old Jun 9, 2003 | 11:04 AM
typeee's Avatar
Default Re: clutch engagment problems (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">
The engagement point for my stock clutch was way near the top, not one inch from the bottom. Weird.</TD></TR></TABLE>
you can adjust the pedal. mine was set near the bottom.
*update*
today everything seems to be back to normal. very strange.
anymore ideas ?
Old Sep 30, 2004 | 09:07 AM
euclid's Avatar
my clutch is having the same problems, its unsprung 6puck though so i know its not the springs. it might be the slave cylinder. im running a search on it now for more info
Old Sep 30, 2004 | 09:11 AM
Bbasso's Avatar
*update*
anymore ideas ?</TD></TR></TABLE>
If it has changed then you have a problem, I suggest dropping the tranny and taking a look, If it were to fail you would or could be stuck somewhere.
Old Sep 30, 2004 | 10:22 AM
Mugen Mike's Avatar
Could definitely be a bad clutch spring. How bad do you beat on the car?
Old Oct 1, 2004 | 07:16 PM
euclid's Avatar
Default Re: clutch engagment problems (Mugen Mike)
my problem is the clucth master cylinder, that might be yours too, check the piston shaft under the dash that connects to the clutch pedal. word is that if it has greese on it or there is brake fluid leaking it is bad and needs replacing, it wont hold the pressure. just becuase your master cylinder tank is full of fluid does not mean the mc is still good. if the mc is bad change the slave cylinder on the tranny too.
Old Oct 2, 2004 | 08:15 PM
euclid's Avatar
Default Re: clutch engagment problems (euclid)
changing the mc and slave did fix my clutch problems, prices were 113$ and 72$ respectively from honda, not remaned they are actually new units. instal was easy and took less than an hour. beats dropping the tranny and replacing the clutch.
EKris
Honda S2000
Jan 20, 2010 07:54 PM
Grease Monkey
Jul 15, 2004 05:39 PM
azian21485
Jul 7, 2004 04:06 AM
typeee
Dec 21, 2002 03:41 AM
Austin
Mar 30, 2002 04:50 AM
