94+ Integra owners..do you have leak problems?
Old Jun 8, 2003 | 01:54 PM
SpeedMonkeyRacing's Avatar
Default 94+ Integra owners..do you have leak problems?
So on my 2000 Integra. I'm having this weak leaking problem. It seems liek when it rains...my passenger side would be flooded w/ water. I checked the sun room and it doesn't leak. And also i reseal the rubber piece going across. Where else you think the water is coming from?
Jeff-
Old Jun 8, 2003 | 02:15 PM
JeepNintegraGSR's Avatar
Default Re: 94+ Integra owners..do you have leak problems? (Corporal-Jeff)
did you check on the fire wall where a hole might be for wires, not factory ones i mean, like a amp wire.
Old Jun 8, 2003 | 02:17 PM
Default Re: 94+ Integra owners..do you have leak problems? (JeepNintegraGSR)
yup. i checked that. it seems like the water is going straight to the back of my passenger side rear seat. my rear qp window rubber is offa little..you think could be coming from there?
Jeff-
Old Jun 8, 2003 | 02:32 PM
PhatboyNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corporal-Jeff &raquo;</TD></TR><TR><TD CLASS="quote">yup. i checked that. it seems like the water is going straight to the back of my passenger side rear seat. my rear qp window rubber is offa little..you think could be coming from there?
Jeff-</TD></TR></TABLE>
Sounds like you need to replace the gaskets on your taillights. Believe it or not, a lot of teg owners have a similar problem where rain leaks through the taillight section. There's a member here that sells extra thick taillight gasket replacements. Hope this helps.
Old Jun 8, 2003 | 02:37 PM
Default Re: 94+ Integra owners..do you have leak problems? (PhAtBoY Si)
but..no water in my trunk..is the spot where the rear passenger side seats are..
Jeff-
Black R
Dec 4, 2016 05:23 PM
FuNkDrSpOt
Dec 28, 2009 08:21 AM
dejavu_88
Mar 14, 2008 05:30 PM
jgulla
Dec 15, 2005 08:02 PM
BadEH2
Mar 24, 2005 09:59 AM
