Leaking valve cover gasket.
Old Jun 8, 2003 | 12:00 PM
rockwilda's Avatar
Default Leaking valve cover gasket.
Ok, i was checking my spark plugs today and when i pulled the wires out there's oil all over them. I peak in and there's oil inside all 4 of the spark plug socket(name?). I'm assuming that the O-ring gaskets are jacked.
My question is, how bad is it to drive like this? im not sure how long it's been leaking. What negative effects are there? As I won't be able to change out the gasket until the end of this coming week.
Any input is appreciated.
Old Jun 9, 2003 | 09:40 AM
rockwilda's Avatar
Default Re: Leaking valve cover gasket. (rockwilda)
cool. thanks guys
Old Jun 9, 2003 | 09:43 AM
.RJ's Avatar
.RJ
there's no negative effects - worst that happens is that the oil seeps down into the cyl and a little bit gets burned off
Old Jun 9, 2003 | 09:52 AM
rockwilda's Avatar
Default Re: Leaking valve cover gasket. (.RJ)
thank you very much.
97ek9
Jun 28, 2007 09:34 PM
honda787
Apr 11, 2007 06:22 PM
CalhounBoi
Oct 1, 2006 05:25 PM
BrokeLude
Aug 19, 2004 11:42 AM
4genaccordfreak
Jan 4, 2004 01:07 PM
