I guess Im SOL regarding a header...
Old Jun 8, 2003 | 11:42 AM
Mark's Avatar
*Bounty Hunter*
Default I guess Im SOL regarding a header...
Since my n1 catback is 2.36", I cant get a good 2.5" header to make good power since it'll create backpressure...
If i wanted to go turbo, I would have to replace the n1 as well (well **** I wish I had researched this before :\)
So since im goin NA, my question is, what is a good 2.25" header? And what cat should I use with it?
Old Jun 8, 2003 | 11:50 AM
ragejed's Avatar
Default Re: I guess Im SOL regarding a header... (94BlackCivicEX)
Comptech, Carsound.
Old Jun 8, 2003 | 01:27 PM
StyleTEG's Avatar
Default Re: I guess Im SOL regarding a header... (ragejed)
There are no headers that have a 2.25" collector that are mass made for our cars. The headers all taper down to 2" so they will fit with the stock cat.
Honestly I think the best 2" collector for b series is the comptech. It is the only non-sequential 4-2-1 header & 2" collector that has stepped primaries to prevent exhaust reversion.
and yes, carsound. Keep in mind that cat diameters are measured ID instead of OD like exhausts.
Old Jun 8, 2003 | 05:09 PM
Mark's Avatar
*Bounty Hunter*
Default Re: I guess Im SOL regarding a header... (StyleTEG)
So for the lazy ppl out there like myself, I should get a Comptech 4-2-1 with 2" collector... What do you mean they are measured by ID and not OD?
Old Jun 8, 2003 | 06:32 PM
StyleTEG's Avatar
Exhausts are measured by the outer diameter, meaning they measure around the outside of the exhaust. Cats on the other hand, are measured by the inside.
You have to keep that in mind in order to get a consistant exhaust system.
Old Jun 8, 2003 | 06:41 PM
Mark's Avatar
*Bounty Hunter*
Ah thx
Looks like I know my setup thus far
94gsr_vtc
Jul 23, 2004 03:40 PM
Heisdan
Mar 10, 2004 05:46 PM
RuskeR
Jun 13, 2003 03:00 PM
RuskeR
Jun 12, 2003 11:09 PM
Unsung
Aug 20, 2002 06:49 PM
