Mounts for d16 in CRX
Old Jun 8, 2003 | 11:39 AM
whoobeedoobee's Avatar
Default Mounts for d16 in CRX
Do you use stock CRX mounts? or a combo of D16 mounts?
Thanks
Old Jun 8, 2003 | 01:30 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Mounts for d16 in CRX (whoobeedoobee)
which D16?
Crx have D16 as a stock engine, so no aftermarket mounts are needed (most of the time).
Stan
Old Jun 9, 2003 | 12:26 PM
Default Re: Mounts for d16 in CRX (90crxsi)
Thanks for the info Stan!
Old Jun 9, 2003 | 01:25 PM
Aron Parsons's Avatar
That makes little to no sense. Anyways, use stock mounts. Energy Suspension engine mounts bushings (inserts) can do wonders on worn out engine mounts as well; however, vibration increases inside the cabin. $20 for a set, definitely worth it.
Old Jun 15, 2003 | 04:21 PM
Default Re: Mounts for d16 in CRX (Aron Parsons)
what makes little to no sense?
Old Jun 15, 2003 | 04:35 PM
RacerBoy's Avatar
Any dseries bolt right in. I don't know about the D16A1 though. You just have to worry about OBD's or just run a vtec controller like I am.
shopa
16
Jan 29, 2016 11:32 PM
vtechboyz
Dec 17, 2008 07:13 PM
Hellraver
Mar 29, 2007 06:50 PM
crex23
Aug 8, 2003 08:11 PM
