NEEDED: p28 ECU pinout
Old Jun 8, 2003 | 06:52 AM
turbotime's Avatar
Default NEEDED: p28 ECU pinout
I need a p28 ECU pinout badly, I have looked everywhere but all I could find was p30. PLEASE PLEASE if you know where a p28 ecu pinout is please post it.
Thanks
Dan
Old Jun 8, 2003 | 08:04 AM
eg6ajk's Avatar
Default Re: NEEDED: p28 ECU pinout (turbotime)
difference between P28 vs p30 is the knock sensor. everything else is the same.
Old Jun 8, 2003 | 08:22 AM
B.'s Avatar
B.
400 HP Club
http://www.hybridgarage.com
Old Jun 8, 2003 | 08:46 AM
Bigjon
Guest
Posts: n/a
Default Re: NEEDED: p28 ECU pinout (THE B)
https://honda-tech.com/zerothread?id=478377
Old Jun 8, 2003 | 08:58 AM
turbotime's Avatar
Ok that is just what I needed, but now there is another problem. I bought a obd2-1 harness off ebay and there is already a wire in the a4 slot where, as I understand it, I am supposed to insert the vtec solenoid wire. Should there be 2 wires or is this a f*ct harness? The wire in there right now is yellow with a black stripe.
Thanks
Dan
Old Jun 8, 2003 | 09:02 AM
B.'s Avatar
B.
400 HP Club
Default Re: (turbotime)
there should only be one wire in there, your v-tec wire, the harnees isn't fucked you just need to remove that pin without damaging it, be careful there a bitch.
Old Jun 8, 2003 | 09:15 AM
turbotime's Avatar
I can remove the wire but it goes back tot he obd2 side of the harness, should I remove it from there as well? And then just click in the solenoid wire to the obd1 side?
THanks man
Dan
FallenEGsi
Jan 16, 2004 10:36 AM
Pfieff
Dec 2, 2003 05:54 AM
dingusjt
Feb 11, 2003 07:16 AM
crazydude75927
Jan 11, 2003 08:08 PM
grumpy92si
Jan 7, 2003 01:50 PM
