Symptoms of a bad fuel pump
Old Jun 8, 2003 | 01:59 AM
CloudDragon's Avatar
Default Symptoms of a bad fuel pump
Well tonight after spraying my car just shut off. After a few minutes I was able to start again. Any ideas?
Old Jun 8, 2003 | 11:29 AM
preluder's Avatar
Default Re: Symptoms of a bad fuel pump (CloudDragon)
your engine misses when at the driving speed range where its supposed to be . like say if your driving normal your car would put,put,pow once in a while. your engine would lope or idle erratically. When your floor the car youll get a surge then youll lose power for a minute then it would kick in. The reaction time at full throttle would be slower than what its supposed to be.,
Old Jun 8, 2003 | 06:33 PM
Default Re: Symptoms of a bad fuel pump (preluder)
Well it's been having a put put put noise for a while now.
Old Jun 9, 2003 | 07:07 AM
LudeyKrus's Avatar
that's prob. the infamous "Prelude Stutter"
Old Jun 9, 2003 | 07:55 AM
preluder's Avatar
Default Re: Symptoms of a bad fuel pump (LudeyKrus)
getfuel to air guage to check . check your fuel filter,sparkplugs,rotor cap, timing, the usual what grade gas are you using. Be careful not tryin to starve that engine out ,fuel pressure regualtor perhaps and new fuelrail.hmmmmmmm
Old Jun 9, 2003 | 08:36 AM
Mikeyslude's Avatar
I was getting a ping ping ping ping in the upper rpm range.
PØNYBØY.85
Honda Civic (2001 - 2005)
Aug 30, 2018 08:39 AM
InvaderJim
Aug 26, 2008 01:18 PM
exsinnovation
17
Jun 14, 2006 02:52 PM
Tony Ignatz
17
Oct 14, 2004 01:20 PM
rasta420
Mar 24, 2003 09:20 PM
