Will auto ECU run properly with m/t?
hi,
i got an obd2 swap but, it came with an auto ecu.
will it work properly in my 5 speed hatch or, will i have to get a new ecu?
i did a search & found out about the pr17 resistor on obd1 ecus but, nothing on whether obd2 is the same.
Modified by Jinxed at 9:59 AM 6/8/2003
If the auto ecu is the same ecu made for the engine that your swapping in, it WILL work without a problem. Only thing is, you will have a constant code 70 because there is no automatic transmission.
panaphobic
May 6, 2008 07:25 PM
panaphobic
May 6, 2008 11:48 AM
