never been to the track, what will my car run on the 1/4 mile (please read)
Old Jun 7, 2003 | 08:15 PM
b16powwer's Avatar
Default never been to the track, what will my car run on the 1/4 mile (please read)
heres the deal, i have never been to a track, if anyone can tell me where around this car should run on a 1/4 mile, i am hoping low 14's or better, but i might be wrong, heres what i got:
1991 honda crx si.
mods are:
b16a1, ported and polished head w/skunk2 intake and exhaust high comp valves, skunk2 springs and retainers, ctr pistons w/stock rings, mugan high comp head gasket, aem short ram intake, thermal catback ss exhaust, power core race cat, jg 4-2-1 header, itr trottte body, skunk2 intake manifold, skunk2 stage 2 cams, skunk 2 cam gears, clutch net clutch and flywheel, walbro 255lph fuel pump, msd 6al w/blaster and coil, ngk 8mm spark plugs, aem fpr (fuel at 45psi), aem fuel rail, lowered about 2", drilled brakes all around w/axis pads, dc short shifter, apex vtec controller, chipped pro mugan ecu to redline at 9300 rpm, vtec set at 6000 rpm, gt grant steering wheel and full int, no a/c or spare tire, 99 si rims w/nito 450 nt's.
post your 1/4 mile time, what the car should do
thank you all at honda-tech.com
Old Jun 7, 2003 | 09:03 PM
g5r's Avatar
g5r
Default Re: never been to the track, what will my car run on the 1/4 mile (b16powwer)
i guess the time you will run is the one when you are done at the track.
Old Jun 8, 2003 | 03:53 AM
J2turbo21's Avatar
Default Re: never been to the track, what will my car run on the 1/4 mile (g5r)
You got so many mods I would have to say atleast a 13's,if not you spent to much money
Old Jun 8, 2003 | 05:48 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16powwer &raquo;</TD></TR><TR><TD CLASS="quote">heres the deal, i have never been to a track..</TD></TR></TABLE>
That right there tells you that you may not make it out of the 15's. Your car will hit low 14's but since you've never ran at the track there is no telling what you will run. Run it and find out.
Old Jun 8, 2003 | 05:54 AM
sander's Avatar
2.7(p/t)
Default Re: never been to the track, what will my car run on the 1/4 mile (nsxmatt)
its allllllll about the driver, nice looking set up though
-sander
b16powwer
28
Oct 17, 2004 10:35 PM
b16powwer
Feb 2, 2003 12:06 PM
all motor crx
Sep 28, 2002 09:26 PM
