**HELP** Front caliper won't pivot out
Old Jun 7, 2003 | 08:11 PM
crx00's Avatar
Default **HELP** Front caliper won't pivot out
I tried removing the passenger side front caliper but it won't pivot out. I unbolted the caliper bolt but when I stick a screwdriver in to pivot out the caliper it won't budge at all. The caliper isn't seized and I can't see anything preventing it from sliding out. Any ideas? I'm stumped.. I just put everything back together and called it a night. This is a 90si BTW. Thanks
Old Jun 7, 2003 | 08:33 PM
FourthGenHatch's Avatar
Default Re: **HELP** Front caliper won't pivot out
Have you compressed the pads? They may be holding the caliper to the rotor.
Old Jun 7, 2003 | 08:39 PM
crx00's Avatar
Default Re: **HELP** Front caliper won't pivot out (FourthGenHatch)
yup.. i compressed the piston
Old Jun 8, 2003 | 12:34 AM
dester223's Avatar
Default Re: **HELP** Front caliper won't pivot out (crx00)
Should remove the 12mm bolt on the bottom, compress the piston slightly and pivot upwards.. Works for me everytime....
Old Jun 8, 2003 | 12:41 AM
AbaZ's Avatar
Well you need to get it out, the slide sounds like it has some build up of rust on it of some sort. As said, remove the 12mm bolt, get a screw driver and pry it so it goes upwards, then slide it off, Besure to use high temp lube/anti seize on the slides when doing brake jobs.
Jeff
Old Jun 8, 2003 | 01:14 AM
crx00's Avatar
Thanks for the tip. Can you explain what you mean by pivoting upwards?
Old Jun 8, 2003 | 01:37 AM
AbaZ's Avatar
Default Re: (crx00)
Once the bolt is removed from the bottom, get a screw driver and pry upwards, the caliper will pivot UPWARDS... slowly push up.. Then push inwards sliding it back and forth to get that ****** off, I'm sure you just got some STANK greese on your slide and its being a ***** to get off.
Jeff
Old Jun 8, 2003 | 02:53 AM
SiR Kid's Avatar
New User
Default Re: (AbaZ)
Old Jun 8, 2003 | 01:48 PM
AbaZ's Avatar
Default Re: (SiR Kid)
Hehe, that's a nifty drawing you got there...
LOWLIFEHATCH
25
May 18, 2023 07:14 AM
B18EG6
Nov 3, 2006 03:01 PM
fleetmack
Dec 22, 2004 09:24 AM
KayOs
Aug 18, 2002 10:35 PM
Flux
Jul 13, 2002 01:10 PM
