90 teg dist. on 89 teg motor
Old Jun 7, 2003 | 06:43 PM
pokemon's Avatar
Default 90 teg dist. on 89 teg motor
possible?
Old Jun 7, 2003 | 07:48 PM
VTgringo's Avatar
Default Re: 90 teg dist. on 89 teg motor (pokemon)
I am 99% sure it isn't. the 90 distributor is off a b17 engine and the 89 motor is a d16 engine. I'm sure it can be done with some modifying of the bolt holes and vacuum hoses.........but then again since i don't have experience with this i could be totally wrong. good luck
Old Jun 7, 2003 | 08:23 PM
91civicDXdude's Avatar
well to clarify, the 90 has a B18A1 engine, and the distributor is compatible with D series SOHC OBD0 engines, im not surea bout d16a1 though..
Old Jun 8, 2003 | 02:49 PM
nikitad's Avatar
Default Re: 90 teg dist. on 89 teg motor (VTgringo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTgringo &raquo;</TD></TR><TR><TD CLASS="quote">I am 99% sure it isn't. the 90 distributor is off a b17 engine and the 89 motor is a d16 engine. I'm sure it can be done with some modifying of the bolt holes and vacuum hoses.........but then again since i don't have experience with this i could be totally wrong. good luck</TD></TR></TABLE>
LOL. I gotta say it - 3 lines of text and no useful info. Not trying to be an ******* but it's funny.
Well, myself I dont have an experience doing that, but as you have said - 90 teg distro is almost the same as 88-91 SI/HF distro.
88-91 SI/HF distro can be made to work with 88-89 Integra engine (D16A1) or with black top ZC. You just need to repin the round plug to a square plug that 89 distro uses. There'll be two wires left sticking out of the 90 distro, just leave them alone - they are for cam angle sensor, and 89 motor has the sensor on a separate cam.
And of course you'll have to get creative with bolting the distro up.
Goinfasterthanu
Apr 28, 2004 08:45 PM
Simple
Nov 21, 2003 08:40 PM
ScottEK
Oct 11, 2002 12:38 PM
brusk
Feb 27, 2002 06:35 AM
