car won't crank unless i reset ecu?
i'm having a weird problem...first off i'll let you guys know what kind of car i have.
88 crx si
b16 w/ pr3 ecu
a month ago...my car went dead at idle....and it wouldnt start back up...it turned over fine...just wouldnt crank...so i checked all connections and fuses...and then disconnected the battery...then connected it back up..to reset the ecu..and it fired right up.....it didnt do it again till tonight..but..it has been taking a little longer to crank.....so tonight it happened again...and i had to reset the ecu...like 3 times...anyone have any idea what this could be? possibly main relay? there is a clicking sound when i crank it down near the fuse box..any help would be appreciated...thanks
oh yeah...the car runs perfect when its cranked...
-corey
88 crx si
b16 w/ pr3 ecu
-corey
i'm not sure if it only does it when its hot....i guess...it really didnt start doing it till the weather warmed up...but...it hasnt really done it every times its been hot....so i'm not sure
saxman
16
Aug 26, 2005 10:00 AM
