aligning shock tower
Old Jun 7, 2003 | 01:21 PM
rasta420's Avatar
Default aligning shock tower
once i put the shock tower assembly together (spring/strut), can the mount on top be adjusted to make it align? or do i have to get it aligned when i put it together? when i mean aligned, i mean aligned with the aligning tab that goes in the fork and the two bolts that go up in the shock tower.
thanks in advance
Old Jun 7, 2003 | 03:24 PM
the DR.'s Avatar
Default Re: aligning shock tower (rasta420)
if you're putting lowering springs in, it usually has enough 'give' to turn the top mount to align into its mounting point, (sometimes thats not the case though.)
edselatlife
Honda Civic (2006 - 2015)
Aug 10, 2016 04:04 AM
sorwdfish
11
Aug 13, 2013 08:14 PM
puresteez
Jul 23, 2013 10:53 AM
CptHMCrunch
May 14, 2013 04:55 PM
