b16 still wont start,have fuel and spark!!
Old Jun 7, 2003 | 11:33 AM
chirp2hrd's Avatar
Default b16 still wont start,have fuel and spark!!
i have fuel and spark and distributor is fine now but still no start..i am running out of tings to check everything is hooked up right im going to check the timing on the cam gears and fuel injector pulse to see if my resistor box is working also im going to check compression is there anything else you guys think i should check?..i have to get this thing started its my daily driver thanks
Old Jun 7, 2003 | 11:49 AM
messeduprex's Avatar
Default Re: b16 still wont start,have fuel and spark!! (chirp2hrd)
Do you have your firing order correct at the cap thats a problem i ran into and it took me three days to figure it out
Old Jun 7, 2003 | 12:26 PM
Redline130's Avatar
All your grounds good, clean, and secure?
Old Jun 7, 2003 | 12:33 PM
durangedesign.com's Avatar
Default Re: b16 still wont start,have fuel and spark!! (Redline130)
check all your fuses, double check the fuel pump, can you hear it turn on? You say you are getting spark right? Take the spark plug out and put it on the block, make sure it is grounded and crack the engine if you see spark then you are getting spark, do it for each one. I ouldn't think it would be timing unless you messed with the before I don't think the timing can go to far off without messing with it to make the engine not start. Make sure your battery is charged full, I know my car won't start but will crank when I have a half dead battery. Other then that it should start for you. If it doesn't then you got a loos connection or maybe your starter is bad.
Old Jun 8, 2003 | 11:49 AM
chirp2hrd's Avatar
Default Re: b16 still wont start,have fuel and spark!! (durangedesign.com)
would it crank if my starter is bad also all grounds are good i have spark and fuel i dono if the injector resistor box is working im gonna check it out
Old Jun 8, 2003 | 03:15 PM
chirp2hrd's Avatar
ttt
sleet_22
Dec 9, 2013 02:09 PM
Corvair64
Dec 27, 2009 02:10 PM
drift2004
Jul 20, 2009 07:46 PM
tarheelsoldier
Mar 15, 2007 08:46 AM
g2turbo
Sep 17, 2003 08:31 PM
