Y8 Mani fo dpfi to mpfi
Old Jun 7, 2003 | 10:19 AM
Turbo Powa's Avatar
Default Y8 Mani fo dpfi to mpfi
Will this work? I would still need to get OBD O injectors and still got to get the ecu and injector box right?
Old Jun 7, 2003 | 10:36 AM
91civicDXdude's Avatar
any d series MPFI manifold will work.
Old Jun 7, 2003 | 11:00 AM
Turbo Powa's Avatar
Default Re: (91civicDXdude)
but i need to get OBD 0 injectors right?
Old Jun 7, 2003 | 12:33 PM
Redline130's Avatar
Default Re: (Panda EK)
Yes, if you are using an OBD0 ecu, then you'll need the OBD0 injectors.
Old Jun 7, 2003 | 01:08 PM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">any d series MPFI manifold will work.</TD></TR></TABLE>
**Except ZC, D16A1**
Old Jun 7, 2003 | 06:30 PM
G2turbo_terror's Avatar
Default Re: (Mr. S)
You need the y8 fuel rail too, I've been hearing lately that only that will work w/the manifold.
Old Jun 7, 2003 | 06:37 PM
pokemon's Avatar
y8 fuel rail is a must no other rail will fit, you won't have an IACV cause the plug is totally diff on obd2 so your idle will fluctuate like a bad tps. I just recently did this swap in a 90 CRX dx with MPFI on a 95 DX motor. Any questions feel free to ask..
Laminate01
Mar 13, 2014 05:59 PM
bonylad
Apr 9, 2008 04:27 PM
iphatcrxi
Nov 14, 2006 10:09 AM
crooked muffler
Aug 8, 2004 08:29 PM
AGS
Sep 17, 2003 06:58 PM
