Electric Load Detector
Old Jun 7, 2003 | 08:21 AM
Si91CRXxX's Avatar
Default Electric Load Detector
Im throwing codes 1 and 20 on the pg7. How do i go abouts checking/fixing why its throwin the code 20? and what is it effecting
Old Jun 7, 2003 | 05:28 PM
hionvtecxda6's Avatar
Default Re: Electric Load Detector (Si91CRXxX)
did the code jusr appear or did you change your ecu? cuz a ecu i used before threw that ELD code. I just changed out the ecu and the code went away
Old Jun 9, 2003 | 05:48 AM
Si91CRXxX's Avatar
Default Re: Electric Load Detector (hionvtecxda6)
yeah, i had the pm6 in and i threw the pg7 in.. Now i figured out what the prob is, cuz the harness is fucked up.. whenever i touch the wires by the ecu, it throws the codes, so i gotta be careful with the wires.. thanks anyway man
T--Rex
Jul 10, 2004 02:15 PM
