can i use a CRX FPR w/ a mini-me swap?
Old Jul 18, 2001 | 07:36 AM
max's Avatar
max
Default can i use a CRX FPR w/ a mini-me swap?
i installed the vtec head form a '92 Si on a '91 CRX and i was wondering if the CRX fuel pressure regulator will do. or do i need to get the one from the '92 civic?
Old Jul 18, 2001 | 10:33 AM
raene's Avatar
Default Re: can i use a CRX FPR w/ a mini-me swap? (max)
I don't see why it wouldn't. If you're worried about fuel pressures then pick up a B&M gauge for your filter. Far as I know the mini-me swap uses the stock fuel rail, therefore it follows it should use the stock regulator.
Old Jul 18, 2001 | 08:51 PM
W0oT's Avatar
Banned
from what i've read and heard you need to use either a FPR from a 92-92 civic si/ex, or you can use any brand adjustable fpr. by the way do you know if the redline changes>? i'm doing this same swap in my 91 si hatch this month. anything i should look out for? did you have any problems installing the head on the block? i have everything i need including a fields sfc vtec controller.
Old Jul 19, 2001 | 09:25 AM
max's Avatar
max
Default Re: can i use a CRX FPR w/ a mini-me swap? (Nismo240sx1)
as far as i know the 91 si hatch has a D16A6 motor, same as 91 si CRX, and its fuel cutoff is 7000. now the 92 si, which uses D16Z6, has a limit of 7200. and considering that if u change the head u basically get the same motor as the 92 si hatch, i'd say the limit will change to 7200. btw, if anyone knows it to be different from what i said, plsease post. as with the swap so far i've had no problems. the head fits perfectly, i used the CRX head gasket cuz it fits as well as the 92 si one. when i was taking out the oil jet from the CRX cylinder block it didnt wanna come out, so what i did was put a small screw in it and then just pull out by the screw head w/ pliers.
Old Jul 19, 2001 | 09:49 AM
W0oT's Avatar
Banned
yeah but doesn't the ecu control the red line or rev limiter? if the rpms will be the same as the d16 that's in the 92-95 ex/si then the tachs would look different because the fuel cut out would be 200 rpms higher. i donn o i'm blabing and prolly confusing you all more
myhatch98
Feb 12, 2006 01:36 PM
PhatboyNYC
30
Aug 1, 2002 05:52 AM
PhatboyNYC
26
Aug 1, 2002 12:51 AM
