What's the spring rate and dimensions of these GC coils? (numbers inside)
Old Jun 7, 2003 | 05:42 AM
g_man80's Avatar
Default What's the spring rate and dimensions of these GC coils? (numbers inside)
Not too long ago I ordered ground controls and asked for the integra rate springs. I looked at the numbers marked on the coils to make sure I got the integra rate springs and I can't figure out the specs.
Front: 200.64.67
Rear: 180.64.44
I assumed the first number was the weight (English units) and figured they were too light for an integra. But then I was thinking they aren't US units because of the other two numbers.
Could someone please let me know how the dimensions work. Is it weight.width.length? And also what are the units?
Thanks,
G
Old Jun 7, 2003 | 06:39 AM
CXHatchback's Avatar
Default Re: What's the spring rate and dimensions of these GC coils? (g_man80)
First number is spring length in MM. (About 7" and 8")
Second number is spring diameter in MM (About 2.5")
Third number is spring rate in KG/MM. Use this chart:
http://www.anzwers.org/trade/h....html
Old Jun 7, 2003 | 09:42 AM
g_man80's Avatar
Default Re: What's the spring rate and dimensions of these GC coils? (CXHatchback)
Hey, thanks a lot. That chart is definitely helpful. By looking at that I'm assuming the third numbers are actually 6.7 and 4.4 kg/mm which (using that chart) would equate to 375 and 246 lbs/in.
Thanks again for the help.
G
volkanerr
Suspension & Brakes
Jun 30, 2011 02:18 PM
kasperxtcy
Suspension & Brakes
Feb 16, 2008 07:59 AM
Doctor CorteZ
Feb 27, 2002 06:07 PM
rockwilda
Aug 8, 2001 09:35 AM
