can someone post the formula to figure out engine sizes.
Old Jun 6, 2003 | 10:31 PM
Nice_Dc2r's Avatar
Default can someone post the formula to figure out engine sizes.
can someone post the formula to figure out engine sizes. and can u also please post sizes of the b16 b17 and b18c cranks
Old Jun 6, 2003 | 10:33 PM
Chris y0!'s Avatar
Default Re: can someone post the formula to figure out engine sizes. (nice_eg)
haha...
cc...ci...liters?
Old Jun 6, 2003 | 10:36 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
what would you guys do w/out me:
Rod ratio= Center line to center line length of the rod / Stroke
1.74 or greater is most desirable for racing
Air temperature = every 7 degrees F >60 degrees F= 1 % loss in
horsepower
CI displacement = bore x bore =__ x .7854 =__ x stroke: divide by .061
for CC x number of cylinders
Compression ratio: Volume of the cylinder, piston dish and head dish and
headgasket from top to bottom of the stroke, divided by the head, piston,
and headgasket volume or:
bore(in.) x bore(in.) =__ x .7854 =__ x stroke (in.) =__/ .061=__cc of
cylinder + (head cc +piston cc + headgasket cc) / (head cc+ piston
cc+headgasket cc) = compression ratio
Piston speed in fpm= stroke (in.)x rpm/ 6
Piston speed desired= 5800 fpm or less
Horsepower= rpm x torque/5252
Altitude effects on HP: every 1000 ft + = 3% loss in HP
Engine CFM approximation: RPM x C.I. displacement / 3456 = approximate
CFM: Example, Civic 1.6, 97 C.I x 7200 RPM = 698400 / 3456 = 202
approximated CFM
Calculation for CFM from HP: HP x .5 (BSFC) = __lb. per hour fuel x 13.2
air/fuel ratio = __lb. air per hour / 60 minutes per hour = __ lb. per
minute / .07 = CFM. Example: Civic 1.6, 127 hp x .5 = 63.5 lb. per hour
fuel x 13.2 air fuel ratio = 838.2 lb. air per hour / 60 minutes per hour
= 13.97 lb. per minute / .07 conversion to CFM = 199 CFM
Injector flow increase vs. fuel pressure increase:The square root of the
new fuel pressure / original fuel pressure x the original fuel injector
flow =__ new flow in lb. per hour: Example 1.6 liter Civic with Auxiliary
Fuel Pressure Regulator: Take the square root of 70 psi(new rail
pressure) / 40 (original rail pressure) = 1.3229 x 24 lb. per hour =
31.75 new flow rate in lb. per hour
Injector sizing for horsepower: Desired HP x .5 (BSFC)=__ lb. of fuel
required for desired HP / __amount of injectors =__lb. per injector x
__duty cycle = __lb. per hour per injector
Fuel pump or injector horsepower capability = Pounds per hour@fuel
pressure desired x 2 =__ HP capability
Gallons per hour to Pounds per hour= __ gallons x 6=__Lbs per hour
Old Jun 6, 2003 | 10:37 PM
navin's Avatar
Default Re: can someone post the formula to figure out engine sizes. (vtecvoodoo)
where'd you copy and paste that from Ryan
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: can someone post the formula to figure out engine sizes. (navin)
from my own post, which was about 6 months old
Old Jun 7, 2003 | 01:26 AM
ill phil's Avatar
Nice post voodoo - My lazy *** woulda just posted the displacement formula
Old Jun 7, 2003 | 12:04 PM
Nice_Dc2r's Avatar
Default Re: can someone post the formula to figure out engine sizes. (ill phil)
what is the stroke of the b17 crank
Old Jun 8, 2003 | 11:17 AM
V3locity's Avatar
DAMN!!!
That is alot of formulas.....copied, pasted and saved!!
Old Jun 8, 2003 | 11:44 AM
Richard.'s Avatar
Default Re: can someone post the formula to figure out engine sizes. (illdezignzls)
holly crap Ryan... good ****..
thecruzs2007@yahoo.com
Sep 27, 2009 12:08 PM
wm5holla
Jul 25, 2003 08:05 PM
vtecvoodoo
30
Nov 10, 2002 10:35 AM
vtecvoodoo
Jun 27, 2002 07:59 PM
jt-sport
Mar 17, 2002 07:37 AM
