can i use 94+ teg e-brake cables for rear disk conversion
Old Jun 6, 2003 | 09:57 PM
ef civic's Avatar
Default can i use 94+ teg e-brake cables for rear disk conversion
i have crx si rear disk and trailing arms but right now i am using crx si cables that i modifide to fit but need a firmer fell will the 94+ teg cables work?......thanks
Old Jun 7, 2003 | 11:30 AM
nautica_t's Avatar
Default Re: can i use 94+ teg e-brake cables for rear disk conversion (ef civic)
hey efcivic i hvae 96 gsr trailing arms..the whole 9 yards, but i haven't put them on yet, but i talked to a guy named KS-R and he said it'll fit, but the 3 brackets wont' all fit, so only 2 would, if you put the 3rd on, it'll be tight and it'll lock up your brakes. but he said it should fit yes.
Old Jun 8, 2003 | 12:06 AM
xsellxoutx's Avatar
they'll work but they are too long and will hang down.i HAD them on my hf but,one day i felt something jerk under the car and when i got home my e brake was crap.
Old Jun 8, 2003 | 12:09 AM
xsellxoutx's Avatar
Default Re: can i use 94+ teg e-brake cables for rear disk conversion (xsellxoutx)
p.s. try tightening your Ebrake it's a 12mm nut on the butt of the lever between the two cables
jaypain
Apr 9, 2009 08:47 PM
donvito#1
Feb 11, 2007 09:26 PM
pac_crx
Jul 15, 2006 05:53 PM
NsX_CrX
May 28, 2004 08:21 AM
Bob_Digi
Aug 22, 2003 08:03 AM
