need help with obdo-obd1
i got a harness from lowchas racing and a parer that can with it said to Repin the OBD1 Distributor to matth the (88-91) OBD0 Pluug as well. this is fairly easy. Just match all the colors up. there should be <U>2 white wires that are on the OBD0 distributor plug and only one on the OBD1/2 plug.</U>
what do i do with the 2 white wires?
any one done this befor i dont get it?
and is that all i have to do to my wiring? for my Gsr motor?
</U>
</U>
the OBD0 side will have two white wires and the OBD1 side will ahve a white and a yellow and green wire. Just hook one of the whites to the white and the other white to the yellow and green wire. If he car won't start just swap the white wires.
Andy
Andy
The 2 white wires on your engine harness are different gauges (one is slightly thicker than the other). The fatter wire goes to the yellow/green on your OBD1 distributor, and the smaller white on your engine harness goes to the white on the OBD1 distributor.
crexer
21
Dec 11, 2005 10:52 PM
Dancing is Forbidden
Dec 1, 2005 09:14 AM
