removing exhaust baffling
Hi...I've never had a bike before and I just got a 954RR for graduation. I like the look of my stock exhaust, but want something a little louder. Is there anyway I can remove some of the baffling in the stock exhaust without adversely affecting the bikes performance. Thanks.
Yeah, I realize you can have a pretty loud aftermarket system. But I was wondering if there was anyway to make my stock system a little louder. Thanks again
Depending on how much you gut, and how responsive the ECU is, it will effect performance. You're removing back-pressure and increasing flow. If the ECU doesn't compensate sufficently, you'll be running lean. It's a bit safer to drill holes in the baffling than to gut it wholesale. It's a LOT easier to just buy a slip-on and be done with it. Throw on a D&D, those are loud as crap.
As a side note, I hope you took the MSF, and good luck.
Thanks a lot project_mercy, good info. Do you know of anywhere we I can find some info on how to drill through the baffling and do it correctly, maybe a website or anything? Thanks again.
You could try glass packing. I helped my buddy repack a 748 and it sounds almost identical to termigoni's. Course imo those don't sound that great either. Drilling/removing baffling will give you a raspy ting well before you get any appreciable increase in muscular exhaust tone. You also have to be careful as the 954 should have 2 cats. One in the exhaust can. I believe its welded directly to the case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga »</TD></TR><TR><TD CLASS="quote">You could try glass packing. I helped my buddy repack a 748 and it sounds almost identical to termigoni's. Course imo those don't sound that great either. Drilling/removing baffling will give you a raspy ting well before you get any appreciable increase in muscular exhaust tone. You also have to be careful as the 954 should have 2 cats. One in the exhaust can. I believe its welded directly to the case.</TD></TR></TABLE>
How does repacking make the sound different, do you just pack less or what?! Thanks for suggestions, this sounds interesting, maybe I'll give it a try when I learn a bit more.
PrecisionH23a
Honda Motorcycles
23
Jun 21, 2005 08:54 PM
