Ok I know nothing about bikes...
Old Jun 6, 2003 | 10:47 AM
dustin's Avatar
Default Ok I know nothing about bikes...
But I need to find (somewhere) a rear sprocket with tooth count in the mid/high twenties (do they make these?). Needs to work with 520 chain.... Does not matter which bike it is for.
I'm working on a project..
Old Jun 6, 2003 | 09:54 PM
busa1300's Avatar
Default Re: Ok I know nothing about bikes... (dustin)
yes most bike have a differnt mounting pattern as far as mounting sprocket to the wheel.
Old Jun 6, 2003 | 11:36 PM
dustin's Avatar
Default Re: Ok I know nothing about bikes... (busa1300)
Yeah that doesn't matter for what I am doing. 34 is about the lowest tooth count I can find, I guess that will probably be fine.
Old Jun 7, 2003 | 12:02 AM
Kris's Avatar
http://www.sprocketspecialists...shtml will those work? They are motocross I think, and BTW what kinda project are you working on? A Gixxerkart?
Old Jun 7, 2003 | 09:47 AM
dustin's Avatar
Default Re: Ok I know nothing about bikes... (Kris)
It's not a gixxerkart, but it will have a Ninja 500 engine... I had planned to put it together a while ago, but then I saw the gixxercart video and decided now was the time.
Hmm. Those look like they might work... but does aluminum wear down quick? Seems like aluminum wouldn't last long on a sprocket.
I did find a 28 tooth rear sprocket on there though, for a Kawasaki KSF-250
MOJAVE... Is that an ATV?
Old Jun 7, 2003 | 11:02 AM
eg94b18's Avatar
aluminum sprokets are ****..............my friend had one on his bike and after a short time the teeth started breaking off.they are made for race bikes that need less weight and are replaced frequently.also yes i believe the mojave is a 4 wheeler.
Old Jun 7, 2003 | 02:18 PM
Jason's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">It's not a gixxerkart, but it will have a Ninja 500 engine... I had planned to put it together a while ago, but then I saw the gixxercart video and decided now was the time.
MOJAVE... Is that an ATV?</TD></TR></TABLE>
I was doing a little research and the 520 chain seems to only be used on the Kaw 500 M/C...is that the only option you have or could you use something else? most bikes use a 525 or 530 and would expand your possiblities greatly.
I have an OEM rear sprocket from my 99 Kawasaki ZX7 that you are welcome to have, but it's for a 525 chain and is more that 20 teeth...let me know if it's something you need, it's just sitting in my garage anyway...
let me know if there's anything else I can help you with
Old Jun 7, 2003 | 02:43 PM
dustin's Avatar
Default Re: Ok I know nothing about bikes... (Jason)
Hmm, I just thought the ninja 500 used a 520 chain. I need whatever works with the stock ninja 16 tooth front sprocket, and the chain to go along with it.
I can replace the front sprocket if necessary to make everything work.
To get the gearing right, I need the largest front sprocket and the smallest rear sprocket... and whatever chain goes with them I think around a 28-30 tooth rear would work nicely.
Dustin
Old Jun 7, 2003 | 02:47 PM
dustin's Avatar
See
From those sprocket people they say that the EX500 uses:
EX-500 87-02 298 42/ 41 33-74 B 42 /45 F 520-104 504K 16 11-17 D
shows 520 chain. Or is this a different EX500? I thought EX500 = Ninja 500...
Old Jun 7, 2003 | 02:51 PM
Jason's Avatar
yes, the EX500 is the Ninja 500...I would probably have to know a little more about the specifics of your setup to help you out though...distances, positioning of sprockets, etc...
Old Jun 7, 2003 | 03:02 PM
dustin's Avatar
Hmm well imagine a go kart like this:
With the entire rear of the kart extended back a foot or so, and this in place of the motor:
Old Jun 7, 2003 | 03:19 PM
Nikos's Avatar
Where are you plannning to get the frame from? Are you going to weld it yourself?
Old Jun 7, 2003 | 03:24 PM
dustin's Avatar
Default Re: Ok I know nothing about bikes... (2 B 4GO10)
I am sourcing an old shifter kart frame. It will have to be modified (aka, cut up and rewelded) in the rear, though.
Old Jun 8, 2003 | 06:51 PM
dustin's Avatar
Anyone know if there is some way I could run, say, a 428 chain & sprockets? I'd need a front sprocket that fit the ninja 500 motor and took a 428 chain... any ideas?
Do you think 428 chain is too small, i.e. will I break it?
Old Jun 9, 2003 | 10:53 AM
big pete's Avatar
hey dustin...how is the shifting going to work? because on the gixxercart, it doesnt look like he has a clutch
Old Jun 9, 2003 | 10:57 AM
dustin's Avatar
Default Re: Ok I know nothing about bikes... (big pete)
Gixxercart has a clutch. It's on the steering column like all shifter karts.
Here is my kart, just picked it up yesterday:
You can see the clutch handle in this pic:
Old Jun 9, 2003 | 10:59 AM
dustin's Avatar
I might have the sprocket thing figured out, but I would still like to find a front sprocket that fits a 428 chain and will fit the EX500 countershaft.
Any ideas? Is there a 520-&gt;428 chain kit for the EX250/500??
Old Jun 9, 2003 | 05:17 PM
big pete's Avatar
ahh ic....nice kart....let us know when you get that thing up and running
Old Jun 9, 2003 | 07:33 PM
nerdish's Avatar
That.. looks .. like.. fun.
Old Jun 9, 2003 | 07:50 PM
tonydatyga's Avatar
you may have trouble finding a 428 front countershaft sprocket that will fit the 500twin. I have the ex500 bike. The bike comes w/ a 520 from the factory and the aftermarket trend is to go with smaller chains down to 520 for streetbikes. Since it already has a 520 chain, there is not real market for a smaller chain kit. There is also no support for increasing the chain pitch to 525 or 530 as far as I know. I believe the 428 is a dirt only pitch but I really have very incomplete knowledge on dirtbikes. Aluminum sprockets will last if they're treated. Untreated rear sprockets tend to wear quickly, especially when the owner fails to properly clean, lube and adjust the drive chain. Also using an old chain with a new sprocket will increase wear.
Old Jun 10, 2003 | 03:40 PM
Nikos's Avatar
Default Re: Ok I know nothing about bikes... (tonydatyga)
how much did the frame cost?
Also, are you aware that if you do build it, it can really hurt you?
I have driven a 125cc 2 stroke go cart and I can't imagine more power.
Old Jun 10, 2003 | 04:41 PM
dustin's Avatar
I paid $1200 for the rolling chassis.
My bathtub can really hurt me.
I found a guy that is machining me a 520 sprocket for a 40mm axle. So I think I am good to go
Old Jun 10, 2003 | 07:27 PM
tonydatyga's Avatar
Actually if you get a choice, looks into a 525 setup. You get a lot more grip than the bike does... a lot more shock ia possible. Plus the 525 pitch has every tooth count you can imagine. Also make sure you check those valve clearances!! I'm interested in your transmission/shifter setup. Please do post pics whenever you get around to it. Thanks
Oh yea, love your bucket seat Brakes are interesting
Old Jun 10, 2003 | 08:44 PM
91hatchcivic's Avatar
damn that cart looks soooo sweet, i want one
Old Jun 11, 2003 | 08:42 AM
Nikos's Avatar
Default Re: Ok I know nothing about bikes... (91hatchcivic)
Dustin,
I htough you might find this interesting
http://cgi.ebay.com/ebaymotors...98067
