ZC tranny question
Ok I have an 89 CRX w a 90 ZC swap it says on the block)and right now it has an si tranny on it which the main bearing went bad-heres my question...Im swapping a dx tranny on my car off of a 90, will I have to change the clutch and flywheel or can I use the same setup and bolt the tranny directly on since they are both 90's?
LMK asap because I would like to get this done today....thnx
i agree with dj........ 88-89 is 20 spline compared to 21 for 90-91........ i was worried about the same issue when i got a used si trans...... but luckily it was a 90 like the seller told me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloorex »</TD></TR><TR><TD CLASS="quote">i agree with dj........ 88-89 is 20 spline compared to 21 for 90-91........ i was worried about the same issue when i got a used si trans...... but luckily it was a 90 like the seller told me </TD></TR></TABLE>not quite right - 88 is 21 spline - 89, 90 and 91 is 20 spline
1989rexsi
Nov 3, 2007 04:47 PM
See Are X
13
Nov 22, 2006 05:47 PM
97grnrs
10
Nov 12, 2006 03:45 PM
