LS turbo piping...will it fit a CRX?
Old Jun 6, 2003 | 08:29 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default LS turbo piping...will it fit a CRX?
Will piping made for an LS integra work on a CRX with an LS...i mean i know that it will need some modification but will i need to buy any extra pipes for it? Also would a high flow fuel pump that was made for an LS work in my CRX? Thanks
Sean
Old Jun 6, 2003 | 09:05 AM
Charlie Moua's Avatar
Default Re: LS turbo piping...will it fit a CRX? (sCeRaXn)
well actually the piping on the LS will need a lot of modifications in order to fit correctly depending on your turbo setup and intercooler.
Personaly if your were going to get a piping kit not made for the ef it would be easiest to use either the EG or ek. (eg would best fit)
as for that fuel pump was it an "intank fuel pump" or inline fuel pump?
If it is an INtank than you would have to check with the manufature about the accapiblity with-in each part #
If it's an inline fuel pump the LS fit should work on your ef
Old Jun 6, 2003 | 12:24 PM
sCeRaXn's Avatar
Default Re: LS turbo piping...will it fit a CRX? (Charlie Moua)
Well the car i might be buying the kit from is an integra LS. Its a revhard mani with a t3/t4 and a 26 inch long spearco intercooler(26x6x3). I just hope that i will be able to hack and reweld the ones that i have and not have to buy anymore. Also...the downpipe is for an LS too...will i have to modify it? Im prolly going to have to do the same thing i did with my header. And the fuel pump is an MSD 125psi and its inline . Thanks
Sean
Old Jun 6, 2003 | 12:34 PM
IntegraXSi's Avatar
What year TEG is it.. If its a DA then it will "bolt up" pretty close
Old Jun 6, 2003 | 01:45 PM
sCeRaXn's Avatar
Default Re: (IntegraXSi)
Im not sure what year it is to be honest with you. Ill ask her when i get the chance. Thanks
Old Jun 6, 2003 | 02:00 PM
Flexmyrex's Avatar
Default Re: (sCeRaXn)
92+ civic 94+ teg intank pump will work in your ef, you will just have to bend the bracket a little to make the pump sit in right.
i had a 94+ teg walbro pump in my crx
hawaiiangsr
Apr 9, 2007 04:12 AM
primetimedx
Aug 22, 2006 02:42 PM
dropd4door
Jan 22, 2004 10:00 AM
MiChangCRX04
Jul 7, 2003 06:17 PM
sCeRaXn
Jun 7, 2003 05:17 AM
