Is there any difference between 88-89 CRX SI and 90-91
Old Jun 6, 2003 | 02:06 AM
Stanley's Avatar
Default Is there any difference between 88-89 CRX SI and 90-91
i know they are 100 lbs lighter, but that's all i can find. I'm thinking about getting a crx, just wanted some more info
Old Jun 6, 2003 | 03:16 AM
jc836's Avatar
Default Re: Is there any difference between 88-89 CRX SI and 90-91 (Barbados88)
Generally speaking No difference except that certain models of the car are indeed lighter and the 90-91 have disc brakes in back. IF you plan to race in either SCCA or NASA be very careful about what you get. SCCA Improved Touring does NOT permit any form of engine swap and you must use the same type motor as originally came with the car-no up/down grading of engines/gearboxes. So if you buy an Si that is the motor/tranny you must use (D16a6/L3).
On the matter of SOLO classification-that is a different story as would also be the case with several other situations where the organizations let you run what you bring-if it passes their tech inspection.
Personally we bought the '89 Si because it was available at the right price and required no real work. Granted a 14 year old car may need some touchup-ours was in a hailstorm so repaint was needed-no rust. Find a very clean car. Worry not about the brakes. Select what you need to either build a race setup or something else. Good luck
Old Jun 6, 2003 | 03:51 AM
brian estrada's Avatar
Yes, there are differences
» 88-89 CRX's don't have side impact beams in the doors, the 90-91 do.
» All CRX's have rear drum brakes except the 90-91 Si's
» 90-91 have a round instrument gauge cover while the 88-89 one is more squarish.
» 88-89 door moldings are taller and flatter, the 90-91 ones are shorter but stick out further and have a beveled edge to them.
» 90-91 rear lights have a 1/2 inch black edge all the way around them, the 88-89 do not.
» 90-91 have have fake air ducts molded into the bumper.
» 88-89 have slightly different front and rear bumpers than the 90-91.
» 90-91 bumper mounted turn signals are clear with amber inserts in them, the 88-89 lenses are just solid amber and shorter in length.
» 88-89 Corner mounted parking lights have their mounting screws visible while the 90-91 ones are attached by hiden screws.
» 91 and perhaps 90 headlights have a vent in them to help prevent moisture buildup.
» 90-91's are the heaviest, the 89 is lighter, and the 88 is the lightest. In each year the hf is the lighter model, then the DX and finally the Si weighs in at the most.
» 88 manual transmissions have an input shaft with 21 slpines.
» 88 has a 21 spline input shaft, the 89-91's have a 20 spline shaft.
» 90-91 clutch is 212mm, the 89 is 200mm and the 88 has either a 200 or 190mm.
» 88 does not have a clutch safety switch. Which means it will start without having to press the clutch in.
» 88-89 Si models have 105hp, the 90-91's have 108hp due to different ecu settings and possibly a slightly different cam.
» 88's have pillar mounted seatbelts,90-91 have door mounted belts, 89 si's and dx's have door mounted belts, 89 hf's have pillar mounted belts.
» Models with door mounted belts have a wider pillar at the end of the door to accomodate the belt mount, this also means that the glass is and inch or so shorter.
» 90-91's have a red seatbelt warning light built into the dome light.
» 88's have what Honda called "passive rear steering" which makes them slightly more agile but some owners complained that they didn't like the "twitchiness" feeling of it so it only existed the one year.
» Rear lower control arms changed between the 88 and 91 years and the rear shocks have different mounting points.
» 88 has slightly different sized front shocks.
» 88 ecu has a different internal design than the 89-91 but the inputs and outputs are the same and ecu's can be swapped between years.
» 88-89's have the hazard light switch on the top of the steering column, 90-91's have it mounted on the dash.
» 88-89 Si seats have a white pinstrip, 90-91 Si seats have a red pinstrip.
» 88 has a pocket at the bottom of the drivers door.
» 90-91 Si's and perhaps the 89 Si have a mesh pocket on the back of the seats.
» 88 cam indexing is the same for all the engines, 89-91 si's have indexing that is different from the other engines.
» 90-91 and possibly the 89 have larger reverse lights that are set further to the sides than the 88.
Information above originated from: Quick Honda.
Old Jun 6, 2003 | 05:30 AM
Mr Furball's Avatar
Default Re: Is there any difference between 88-89 CRX SI and 90-91 (jchxcrx)
thanks for the write up. someone should sticky this
Old Jun 6, 2003 | 06:17 AM
WhatThaFrig's Avatar
Default Re: Is there any difference between 88-89 CRX SI and 90-91 (FURBALL B-16)
That is some great info.
Old Jun 6, 2003 | 08:03 AM
Default Re: Is there any difference between 88-89 CRX SI and 90-91 (WhatThaFrig)
np... i found it on http://www.crxsi.com a long time ago...
it was a miracle that i remembered...
that info is probably the main reason that i looked so hard for a '91 Si
Old Jun 6, 2003 | 11:12 AM
PoonHunter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jchxcrx &raquo;</TD></TR><TR><TD CLASS="quote">Yes, there are differences
The 89 got the cam upgrade to make 108hp and 89 did have the warning seatbelt light on the domelight at least mine does and other ive seen
WestSide209
Dec 8, 2010 01:01 AM
crx18c1
Dec 27, 2006 09:02 AM
pushinglikekrazy
Feb 4, 2006 02:38 PM
pushinglikekrazy
Feb 4, 2006 02:27 AM
91CRXpusher
15
Jul 31, 2003 09:43 PM
