Can I put a ex or a crx si head on my crx hf?
Old Jun 5, 2003 | 09:58 PM
Ghost Rider's Avatar
Default Can I put a ex or a crx si head on my crx hf?
I wanna know if I can put a civic Ex head or a crx Si head on my crx Hf to make it have v-tec. If so would the only other things I need to run it would be the computer and wire harness right?
Old Jun 5, 2003 | 10:01 PM
incubus's Avatar
Default Re: Can I put a ex or a crx si head on my crx hf? (Ghost Rider)
CRX si = d16a6 = no vtec
next time use the search function first,
you are better off just swapping the whole motor out for a d16z6 or d16y8 from a 5th gen or 6th gen civic.
Old Jun 5, 2003 | 10:35 PM
turbotime.'s Avatar
lol
Old Jun 5, 2003 | 10:46 PM
88crx Osaka's Avatar
CRX HF has 2 valve reliefe on pistons.
So NO 16 valve for you hhahahahahhaha.
Old Jun 6, 2003 | 06:53 AM
Aron Parsons's Avatar
Default Re: Can I put a ex or a crx si head on my crx hf? (incubus)
You can't put a Z6 or Y8 head on your HF motor because it is only has 8 valves. A 16 valve head will not work on your motor.
Your best bet is to find a used D series motor (can be had for very little, probably less than $200). It is a direct replacement in your car, with no wiring changes involved at all (for an A6, a Z6 or Y8 motor would need some wiring changes). Pull the old motor out, put the new one in. You'll also want to get a DX or Si tranny, as the HF gears are much too tall if you want any performance from your vehicle. An Si ECU also goes along with the package, but that shouldn't be a problem to find either.
Do a search to find lots of information. Most of your questions you will have have already been answered.
Old Jun 6, 2003 | 07:26 AM
1_bad_EF's Avatar
Default Re: Can I put a ex or a crx si head on my crx hf? (88CRX)
d16a6 have vtec??????????
To put any 16 valve head on an hf block, you have to grind valve reliefs in the pistons.
Old Jun 6, 2003 | 10:56 AM
MIRRAdekhtc's Avatar
Default Re: Can I put a ex or a crx si head on my crx hf? (1_bad_EF)
a6(si) no vtec
z6 or y8 (92-95. 96-00) vtec
i'm curious to know if anyone on h-t makes a conversion harness for putting in a 92-95 ex, d16z6 into a 90 crx hf.. and converting it to obd-1..
i know hasport makes one and it converts your car to obd-1, and you can use the p28 ecu...But does anyone on h-t make custom ones?
1990JDMCRX
10
Apr 2, 2009 06:39 PM
Nephalim Xero
Feb 2, 2006 10:08 AM
DarkZachiel
Jan 5, 2004 09:28 PM
chet
Apr 26, 2003 08:58 AM
