Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Proportioning valve- 40/40 anyone done a before and after??
Old Jun 5, 2003 | 09:31 PM
SOUNDEFFECTS's Avatar
Default Proportioning valve- 40/40 anyone done a before and after??
Has anyone changed from a 30/30 to a 40/40 with any kind of improvement?
This would be done on a car that just got upgraded to Integra Discs all around. Already have the booster/master cylinder but front locks up pretty quick--ok?
Old Jun 6, 2003 | 08:23 AM
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (SOUNDEFFECTS)
Come on did anyone have some positive results?
Old Jun 6, 2003 | 01:01 PM
TodaSi's Avatar
What car?
What brakes?
Old Jun 6, 2003 | 10:38 PM
markw's Avatar
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (TodaSi)
I did the teg/CRX rear disks on mine with the fastbrake 11"/oem caliper fronts. Went to the 90-91 15/16" EX MC and did the 4040 valve. Brakes are just awsome. Put 80 miles on it out at Holtville which is very hard on brakes and it didn't fade even once. Carbomet front pads, raybestos (they were still good when I got them) rears. This is on a 90 CRX DX
Old Jun 7, 2003 | 10:09 AM
6ghatch's Avatar
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (markw)
From what I've been told, Honda's don't use front to rear bias proportioning valves. They work diagonally and just separate the front left and right rear from the front right and left. The brake bias is based on pad compound, caliper size, and rotor size.
Old Jun 7, 2003 | 04:27 PM
civicrr's Avatar
If this is a 5th gen Civic with a 3rd gen Integra disc swap, I think that you want the 30/40 valve (40/40). That is what I used on my car. I initially did the same swap without the pro. valve. While I did get improved braking, I experienced too much front brake bias. I changed out to the 30/40 (IIRC- not home to actually check it) which is the same one used on the 5th gen Civic Si, which is a disc/disc car. FYI, that car has the same brakes/rotors f & r as the 94-00 Integra. Braking improved once again.
Check out hybrid.honda.com for a complete story.
Old Jun 8, 2003 | 12:09 PM
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (civicrr)
Exactly the case, I need the 40/40. It works without but the fronts lock up too quickly right now. The 40/40 should change the flow of brake bias to the rear a tad bit more....most junkyards don't keep track of this valve either-I called many
Old Jun 8, 2003 | 06:22 PM
CRX Lee's Avatar
What is the 30/40 or 40/40 you are discussing, what do thiose number means and where do they come from? I have done some brake swapping and conversions over the years and need to put a new adjustable prop valve in the racecar but am not sure of the terminology used.
Old Jun 8, 2003 | 06:34 PM
Crack Monkey's Avatar
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (CRX Lee)
30/40 and 40/40 are the stampings on the factory prop valves from various Teg/Civic models. I don't recall which went with what brake combo.
Old Jun 8, 2003 | 07:23 PM
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (Crack Monkey)
From what I understand
30/30-cx,vx,dx,etc...with 9.5 disc in front and drums in rear
30/40-??someone said from a 2dr ex with 10 disc in front
40/40-is from Integra's with disc all around, they come ABS and without ABS too
Old Nov 8, 2004 | 05:32 AM
pramonn's Avatar
I know this is an old post.....but someone might lookin for.
I have civic EG 92 4 door sedan with D16Y8 M/T power plant form 97 EK.
Have rear disk brake swap for about a yaer with 3030 prop. (front brake still OEM)
It work well on dry road but on wet it kindda wheel lock and make a car slip/fade/slide depend on how wet how fast and how sudden breakin.
With 3030 it feel abit distance of the paddle and then stop dead (that might make it feel good on dry)
Last week I change to 4040. It diff feeling, it feel every inch the paddle travel it incresing brake power and then stop.
But on really hard bake it still show abit wheels lock.....of course not often as 3030
Old Nov 8, 2004 | 05:43 AM
Chris Sawatsky's Avatar
New User
I raced my first 2 seasons with rear discs and a rear drum prop valve on my crx. for season 3, I installed the correct prop valve. I went from 1:13 laps to 1:10 laps consistently, with no other changes (didn't even change the oil between seasons heh)
I think the drum valve was causing too much rear braking, making the car unstable
This was on an ITA crx Si
Old Nov 8, 2004 | 06:10 AM
Targa250R's Avatar
be professional
Swap the proportioning valve. Without it, the rear calipers won't get enough fluid, and they'll do essentially nothing (not that they really do that much in the first place ). We have swapped the proportioning valves in every Civic that we have done a rear disc conversion on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrr &raquo;</TD></TR><TR><TD CLASS="quote">I changed out to the 30/40 (IIRC- not home to actually check it) which is the same one used on the 5th gen Civic Si, which is a disc/disc car. FYI, that car has the same brakes/rotors f & r as the 94-00 Integra. Braking improved once again.</TD></TR></TABLE>
Actually, no . . . only the 1994 Si with optional ABS had 10.3" fronts (with same calipers as 3rd-gen Integra), discs in the rear, and a 15/16" master cylinder.
All other '92-95 Si hatches - including the 1994 Si without ABS - had 9.5" fronts (with same calipers as the non-Si hatchbacks), discs in the rear, and a 13/16" master cylinder.
Old Nov 8, 2004 | 07:02 AM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrr &raquo;</TD></TR><TR><TD CLASS="quote">Check out hybrid.honda.com for a complete story.</TD></TR></TABLE>
I couldn't find that site. Can you provide a link?
Old Nov 8, 2004 | 08:11 AM
RStoR's Avatar
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (thawley)
http://honda.hybrids.jp
Old Nov 8, 2004 | 08:29 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Proportioning valve- 40/40 anyone done a before and after?? (RStoR)
Here is a great article about brake proportioning valves. I leared a lot, and I'm sure you guys will be surprised too...
http://www.stoptech.com/whitep...s.htm
Fliptard
55
Sep 12, 2011 05:48 PM
journeyquest
14
Aug 21, 2011 05:48 PM
blackccoupe
Northeast (Sales)
Oct 2, 2009 08:11 AM
Red_ED8
Nov 3, 2007 08:40 AM
nominous
Oct 27, 2006 02:12 PM
