i want to know everything about skunk stage 3 cams...
hey guys i'm wondering about skunk2 stage 3 cams, how are they and are they worth. Have any of u guys used them. If so did u have any drivability at all. what would i need to have them run efficiently without blowing my motor. thanks for the input.
edit: i hate being mean:
https://honda-tech.com/zerothread?id=518082
https://honda-tech.com/zerothread?id=510000
a good read on s2s2's:
https://honda-tech.com/zerothread?id=427763
Depending on your setup, they might not be the cams for you. They are for highly built engines with massive compression, and require a pro to get them tuned good. What do you need to run them? EF-1 or Toda or Skunk2 valvesprings and retainers.
Also, look the threads posted above, good reading there.
my buddy was running stage 3's on a stock head and that ****** pulled hard. i dunno if that is the case for evey car or if he just got lucky, but that is the only experience i have had with skunk 2 stage 3's
