OT: Clip remover??
I'm trying to pull off the hood edge protector, and in the helms it says to remove those clips with a clip remover. I usually just pull the clips from the fender liner, etc, by prying them with a tiny screwdriver, but I would hate to do this around my hood if I don't have to.
Where can I find a clip remover? I can't seem to find one online anywhere.
I couldn't find one on the sears crafstman website, but I was able to find this one on harbor freight. This one would suffice right?
http://www.harborfreight.com/c...46024
it looks like that might work, but you would probably be able to push the extended tabs inward one at a time with a super small flat-head screwdriver too.
I use a panel popper (i have only found them @ snap-on in the past). It has a flat, split fork end with a curved neck, allows a quick pop removal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muse »</TD></TR><TR><TD CLASS="quote">it looks like that might work, but you would probably be able to push the extended tabs inward one at a time with a super small flat-head screwdriver too.
I use a panel popper (i have only found them @ snap-on in the past). It has a flat, split fork end with a curved neck, allows a quick pop removal.</TD></TR></TABLE>
Opps, im talking about a panel popper.
antman2x2
Honda Civic (2001 - 2005)
Mar 18, 2013 09:15 AM
