Piston ring question
I'm installing rings on my pistons and I had a question for the experienced. Where do you position the ring ends on the top two compression rings. 180 degrees opposite each other? The pistons are Je 84.5mm 11.5 c/r.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20ek »</TD></TR><TR><TD CLASS="quote">I'm installing rings on my pistons and I had a question for the experienced. Where do you position the ring ends on the top two compression rings. 180 degrees opposite each other? The pistons are Je 84.5mm 11.5 c/r.</TD></TR></TABLE>
correct but do not line the up with the wrist pin i always do them at 135 degrees and 270 degrees
You can set them 180 apart, I think that the Helms shows the rings all staggered with none of the open ends along the thrust side of the piston. They will only stay that way for a little bit since the rings rotate in the bore at around 1/100 of the crank speed, once in a blue moon all of the gaps will line up.
I hope that helps, maybe too much info.
MastaFlyMason
Engine Machining & Assembly
Dec 14, 2017 04:08 PM
oxSLEEPERxo
Jun 25, 2007 08:35 AM
