type r cams and valve clearances.
senior gold member
I put in some type r cams in my lsvtec. My idle is rough and the car doesn't rev up correctly. Would the clearances being outta spec cause this?
edit: I messed up on the title. This is for the valve lash clearances.
Modified by Ivan at 9:19 PM 6/5/2003
What pistons and headgasket are you using and is the head milled at all? Just putting ITR cams in a stock LS/VTEC would cause clearence issues.
senior gold member
pistons are CTR and stock headgasket. head is not milled. ahhh man I messed up. I meant the valve lash. the clearances for the valve lash.
jceltalentoso
Jan 27, 2014 08:54 PM
Honda-bond
32
Jan 22, 2011 02:45 PM
