Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Roll stiffness/Spring rate philosophy
Old Jun 5, 2003 | 04:36 PM
Steppin Razor's Avatar
New User
Default Roll stiffness/Spring rate philosophy
Hi all. Before I ask my question, I thought I'd mention I do not road race (I autocross), I'm just asking because I like to know things.
I've read that the standard when setting a car up for racing is that one should tune roll stiffness with spring rates [or springs/shocks] and use swaybars for steer characteristics. My question is, why? What's wrong (or less good) with setting up roll stiffness with swaybars, allowing the racer to use softer springs? Common sense wise, it seems it would be better to have as soft a spring rate as one could get away with since most tracks do have bumps, imperfections, etc. Or am I missing something?
Thanks
Old Jun 5, 2003 | 05:45 PM
Mohudsolo's Avatar
Default Re: Roll stiffness/Spring rate philosophy (Steppin Razor)
Two reasons come to mind right off. With a heavy swaybar any single wheel movement is transferred to the wheel on the other side whether roll from cornering or just a bump. In a turn, body roll pushes up the outside wheels and the heavy bar will tend to lift the inside wheel too. With a light, or no bar, the outside takes the load and the inside stays on the ground.
The second reason is shock tuning. If the shocks are tuned to the spring rate and heavy bars are used, when cornering the shock rate will not be controlling the extra spring rate from the bar. A heavy bar is a very high spring rate in roll so the car ends up underdamped in corners. If the shocks are tuned for the heavy bars, then the car is overdamped when going straight.
Probably a bunch of other stuff I can't think of now.
AlphaKennyWun
Suspension & Brakes
Apr 24, 2009 05:21 PM
azian21485
Apr 9, 2006 05:21 PM
01BLKGSR
45
Mar 25, 2005 03:01 PM
HondaCutter
12
Jan 28, 2004 09:21 AM
lonefuzzy79
14
Sep 8, 2002 07:34 PM
