Changing stock headlamp bulb on a 94 Civic LX
Does anyone have any tips on changing the Left Headlamp bulb on a '94 Civic LX?
Right went out 6 months ago, pain to replace and get the "spring" back on correctly. The left one you can barly get a half hand near the bulb. I can slide the power stearing fluid reserve off it's mount, but that does little to create more room to replace, as the hoses are still hooked up.
I can't remove the headlamp as far as I can tell, unless I remove the bumper (all bolts were removed but hte bumper gets in the way).
Any suggestions before I kick the heck out of the car?
Thanks,
FlynHokie.
Thanks,
FlynHokie.
You can disconnect the clip. Try to look for the clip holder. Just get as much light and clean it. Then use a screwdriver and pry it apart. It might also just twist off, I forget.
Luchini
Dec 29, 2006 08:57 PM
