PCT pistons in LS block questions?
Old Jun 5, 2003 | 01:19 PM
dfoxengr's Avatar
Default PCT pistons in LS block questions?
just randomly curious if you could get away with a Honda 3 layer HG taken down to 1 or 2 layers with JDM b16B pistons in an LS block with stock valves, as far as clearances go? or would you have to use the 3 layer, and or what size HG works? and what other problems would arise?
then how about P30 (jdm b16a) pistons in same setup?
Old Jun 5, 2003 | 02:48 PM
MaxBoost's Avatar
New User
Default Re: PCT pistons in LS block questions? (hybridvteceg)
With 1 layer headgasket and a GSR head the compression would be above 13.0:1, whether or not the pistons will contact the valves you'd have to know what size cams, and on what head. I personally can't help you, but im going to refer this thread to my friend who can probably can.
Old Jun 5, 2003 | 04:41 PM
teg92's Avatar
You are most likely not going to be running stock camshafts, therefore knowing your lift is a big help into determining the answer to your question.
Also, you already probably know that it is not worth risking a joe blow giving his opinion or experience on this particular combination since every motor has slight differences between them. Your head or deck may have been resurfaced a little more than the other guys etc...
The only way to be sure is to clay check your clearances.
Old Jun 5, 2003 | 04:57 PM
dfoxengr's Avatar
Default Re: PCT pistons in LS block questions? (teg92)
stock everything even cams. im not doing this i was just seeking knowledge.
Old Jun 5, 2003 | 06:35 PM
dfoxengr's Avatar
ben_art
13
Dec 2, 2014 03:09 PM
monster_c
Jan 12, 2012 10:48 PM
crxturbo177
Mar 25, 2010 04:13 AM
J_SHADOW
May 26, 2008 06:37 PM
92eg6lsvtec
Jul 22, 2005 12:11 PM
