What is this part called in this picture....
Old Jun 5, 2003 | 01:09 PM
Smoothy's Avatar
Default What is this part called in this picture....
www.geocities.com/mycarcrap/backquestion.jpg <----CUT AND PASTE
Two of the three CRXs have this. What is it, and why doesn't my other CRX have it?
Old Jun 5, 2003 | 01:30 PM
EF Two's Avatar
Default Re: What is this part called in this picture.... (Smoothy)
it's not working for me
Old Jun 5, 2003 | 02:03 PM
Turbo Powa's Avatar
Default Re: What is this part called in this picture.... (DX_Tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DX_Tuner &raquo;</TD></TR><TR><TD CLASS="quote">it's not working for me </TD></TR></TABLE>
Old Jun 5, 2003 | 02:18 PM
crxforum's Avatar
Default Re: What is this part called in this picture.... (Panda EK)
For Geocities you have to add a space at the end of the address and then click enter.
I will host it for you though.
CRX Forum
Old Jun 5, 2003 | 02:19 PM
johnzm's Avatar
Default Re: What is this part called in this picture.... (crxforum)
perhaps its the purge solenoid. or perhaps im stupid
Old Jun 5, 2003 | 02:59 PM
4drEF's Avatar
Keyboard Humorist
Default Re: What is this part called in this picture.... (johnzm)
Looks like purge to me too. It's not hooking up to vacuum or water. It just look slike it's attached to the manifold... like the purge is attached on some d-series manifolds.
Old Jun 5, 2003 | 04:59 PM
MrTodd's Avatar
Default Re: What is this part called in this picture.... (4drEF)
Purge?? LOL, no, the purge solenoid is much smaller than that. Besides, the purge solenoid (on OBD-1 manifolds) is located higher than where this one is - AND do you see any vacuum hose that would connect to the charcoal canister coming from it? Nope.
That is the Fast Idle Solenoid - if the ambient air temperature is FREEZING (below 0) that solenoid will open up, increasing the idle speed past 2k rpms. Only OBD-0 motors had the solenoid located on the back of the I/M, OBD-2 motors completely did away with it, while I think some OBD-1 manifolds had it located somewhere else, if at all.
Old Jun 5, 2003 | 05:57 PM
Smoothy's Avatar
Default Re: What is this part called in this picture.... (MrTodd)
Ok, so why doesn't my other CRX have it? All the diagrams on Majestic Honda also do not have it. Is this something I can just not connect and forget about?
Old Jun 5, 2003 | 06:10 PM
MrTodd's Avatar
Yeah, you really don't need it. When people swap out their d15b2's, or d16a6's to a ZC or any other engine swap, you simply don't use the exhisting wire-harness connector that attaches to it (if your car had it in the first place). Perhaps only high-altitude emission CRX/Civic's had it...
Either way, you don't need it. Disconnecting it wont give you any codes/problems.
Old Jun 5, 2003 | 06:12 PM
martini's Avatar
CA emissions?
jdm_dc_fan
Sep 1, 2008 09:28 PM
metal
Apr 2, 2008 03:48 AM
Peakellz
Jul 19, 2007 04:34 PM
CRX Si
Mar 28, 2005 09:15 PM
Acura EL
13
Oct 24, 2004 01:06 PM
