WTB USDM ITR 5 lug conversion (NO WHEELS)
Not bigger axels, just a larger axel hub (36mm) I want USDM so I don't have to mess with getting the axels to fit on my USDM D series engine.
PasswordJDM's site says
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">JDM ITR 98spec 5 lug 5x114.3 32mm suspension swap $999.00 plus shipping -incl:frnt knuckle assemblies w/brake components, rear trailing arms w/brake components, not incl: wheels/tires, brake lines, lug nuts, axles, lower control arms(LCA), sway bars, or installation instructions. -will fit EG or DC stock axles.
So wouldn't it deal with 32mm axel hubs? (just trying to help out, i plan to get a set in a couple months)
So far as I know, and I'm almost positive USDM ITR had 32mm hubs and JDM CTR 5 lugs had 32 mm hubs. JDM ITR 5 lugs have 36mm hubs, I thinkt they're wrong?
-Jake
-Jake
you are correct.
JDM 98 spec ITR 5 lug is = 36mm
USDM ITR & CTR = 32mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninety2SiR »</TD></TR><TR><TD CLASS="quote">So far as I know, and I'm almost positive USDM ITR had 32mm hubs and JDM CTR 5 lugs had 32 mm hubs. JDM ITR 5 lugs have 36mm hubs, I thinkt they're wrong?
-Jake</TD></TR></TABLE>
I ended up buying a JDM ITR 5 lug from a local seller, great deal, included axels.
You buy the axels seperately for $200 I believe from passwordjdm.com
RhdDc2R
Mar 30, 2007 08:39 AM
